heaters in 6.0L diesel
That's for a block heater. Its installed into a coolant passage just above the starter, and you've found the pigtail at the bumper. It's about 1100wts, IIRC. Most guys put them on timers to run no more than 4 hours before anticipated start time in the cold of winter. To monitor real time engine coolant temps you'll need a digital(OBDII), or analog gauge.
Otherwise, see how warm the air from your cab heater is right when you start it, after being plugged in for a while.
The tag you see most likely refers to the rating of the pigtail itself. It could be factory original, factory replacement, or aftermarket. All 6.0l engines came equipped with the block heater element. Not all had the pigtail.
There is no automatic thermostatic control of any kind. Plug it in, and it's on until you unplug it.
I like to plug in when temps get into the teens(°F). I've started mine cold at -22°F, and the engine was not happy at all, but did start/run.
I'd leave mine in overnight during the winters while I was up on Whidbey, but it was abnormally cool at 17*. That and I had several dead glow plugs, and now that I'm back home in I don't care about them nor do I need the heater.
Which is fortunate, as the last time I went offroading the plug dropped down and got ripped off like $2 hooker's dress on nickel night.
the heating unit is around 1000 watts and will raise you oil temperature to around 100 degrees f after 2-4 hrs, depending on the outside temperature. I plug in under 25 degree f, most of us, use timers because of the electricity costs.
Andrew010
6.7L Power Stroke Diesel
13
11-06-2012 05:15 PM
