6.4 with h&s tuner - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
6.4 with h&s tuner
Old 09-01-2014, 11:29 AM
Hayman12 Hayman12 is offline
Hayman12 is starting off with a positive reputation.
6.4 with h&s tuner
I have a 2008 6.4l with a h&s minimax and 5" exhaust and egr and dpf delete kit it run good but fuel mileage really didn't change much but I put it on a dyno and had the tuner turned up to 300 hp gain and it still only put out 408hp I'm not real sure but I think it should have put out way more hp since it is 351hp stock any help would be appreciated.
Old 09-01-2014, 12:30 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
Something sounds slightly odd, I would start with a reputable truck shop that does this stuff on a daily basis.
Old 09-01-2014, 12:44 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Where did you dyno it? Is the dyno set up for a turbo charged vehicle? The dyno should add resistance to the wheel to allow the turbo to spool properly. Inertia vs Load Cell
Old 09-01-2014, 02:13 PM
Quote:
I had it dyno at a diesel truck show and pulls
Old 09-01-2014, 03:18 PM
RM2738's Avatar
Things I'd check immediately: DTC's, air filter and fuel filters.
I just pulled my S&B air filter out after 25,000 miles and it was so incredibly gunked up, I was astounded the filter minder hadn't tripped yet. What made me check it was a slight decrease in mileage and a slight decrease in the "get up and go" when the skinny pedal was pushed. It's minor and I doubt that's what is holding you back, but it's a few things to look at.
Keep in mind the 300HP Hott damn tune won't get you an additional 300 RWHP.
Old 09-01-2014, 04:06 PM
STROKINMY'08's Avatar
STROKINMY'08 STROKINMY'08 is offline
STROKINMY'08 is gaining momentum as a positive member of FTE.
Quote:
doesn't make any sense at all.... your saying the truck has been running good except it's missing about 150hp....lol.... are you positive the tuner wasn't set at a different level?? There is a lot of variables.. is the truck lifted...big rims?? I didn't see if you have an intake or not.. but definetly helps with the bigger hp tunes.... something seriously wrong with this thread!
Old 09-01-2014, 04:25 PM
RM2738's Avatar
Quote:
I was leading there. Lol.
The newest H&S Flashes have changed quite a bit in how the tunes are uploaded. Maybe you accidentally loaded the 150 tune unknowingly?
Can you go into the settings in the tuner and confirm your version and current tune?
Old 09-01-2014, 05:56 PM
I don't normally run the truck on that setting so I'm not sure how it should run. I will try to reload the tuner again and see if there are any changes. Thx
Old 09-01-2014, 05:58 PM
Oh and the truck is not lifted stock rims.
Old 09-01-2014, 06:01 PM
5" exhaust and s&b intake.
Old 09-01-2014, 07:21 PM
I was like is RM gonna say it or me....lol!! but seriously with your mods...also depending on the dyno and climate wherever you are...you should be putting anywhere from 550-600RWHP to the ground... so if there we're no mistakes during the upload/dyno run then there's something seriously wrong.
6.4L Spartan Tuner w/DPF/CAT Delete Pipes smartken22 Ford Truck Parts for Sale 2 09-18-2015 02:00 AM
amazing performance and gas mileage rjkenney 1999 to 2016 Super Duty 8 04-24-2015 06:04 PM
DPF Delete with H&S Tuner? rjlabonte 6.4L Power Stroke Diesel 3 03-04-2014 06:33 PM
6.4L Power Stroke growling sound from high pressure turbo sam3849 6.4L Power Stroke Diesel 3 12-05-2013 07:12 PM
Tuner Questions Trancebear 6.4L Power Stroke Diesel 44 05-04-2012 09:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
