C Series 389 flywheel ring gear question - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 09-01-2014, 11:09 AM
Fireman32653 Fireman32653 is offline
Fireman32653 is starting off with a positive reputation.
I have a 76 C800 with a 389. The starter was grinding and when I replaced it I noticed a group of bad teeth. I got it started and home but now I need to replace the ring gear or the whole flywheel. Does anybody know which ring gears/flywheels interchange?? I've seen 184 and 188 teeth as options as well as 11 and 15 inch flywheels. There seem to be lots of information but no clear interchange. I'm trying to order the replacement ahead of pulling it apart.
Old 09-01-2014, 08:47 PM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
Check this link out, it seems that all the FT motors used the same ring gear. However there were several different manual clutch flywheel assemblies that were different size, but all it seems used the same size / tooth count ring gear.
http://www.ford-trucks.com/forums/13...rt-number.html
There are even sources listed for the part......
David
Old 09-04-2014, 09:58 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
I've seen 184 and 188 teeth as well as 11 and 15 inch flywheels.
184 tooth ring gear was only used with FE engines (1965/76 F100/350 & 1958/71 cars), there are no such things as FT 11 or 15" flywheels.
Your C800 should have a 13" clutch.
C4TZ-6375-D .. M/T Flywheel - 188 tooth ring gear / Marked: C4TE-6380-J or D2TE-6380-CA / Obsolete
1964/78 FT engine applications: 330 2V Heavy Duty / 359/361 / 389/391 // NOT used with 330 2V Medium Duty engine!
The 359 & 389 were FoMoCo's confusing engine sizes for 1973/78 detuned for smog 361's & 391's.
The ring gear can be replaced by itself.
C4TZ-6384-A .. Flywheel Ring Gear - 188 teeth / Obsolete
Applications: 1964/78 ALL FT engines.
Starter ring gear question -another one Marauder2004 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 05-29-2016 06:59 AM
help with flywheel removal umbagog1 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-23-2015 12:35 AM
Replace Flywheel or Just the Ring Gear qman 1967 - 1972 F-100 & Larger F-Series Trucks 9 06-03-2015 05:21 PM
Ford 200 I6 Flywheel lauxg Ford Inline Six, 200, 250, 4.9L / 300 2 02-28-2015 10:47 AM
c series 389 flywheel question Fireman32653 1999 to 2016 Super Duty 1 08-31-2014 02:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
