Starting my 50 F-2 thread
Old 09-01-2014, 10:01 AM
50 Flathead f-2's Avatar
50 Flathead f-2
50 Flathead f-2 is offline
Sorry I didnt take any pictures of it when I first got it. It is a 50 Flathead F-2 i traded a rust bucket 68 coronet for it. (I wish I just out right bout the Ford and kept the coronet too.) It used to be red white and blue of you can imagine how it looked and the guy said it hadn't been ran in over 6 years so I went through the engine and did just the very basic things too it. to see if it would even run, and it fired right up. I had to run it with a gas can on the fender because it had a FULL tank of very old green slimy rusty gas. Unfortunately, I had to stop working on it for awhile because I got stationed in England. But ive bought a whole new fuel system for it nd bought all new brakes so I will have a lot to look forward too once I get back home! let me know what everyone thinks!
Sorry I couldn't get any more im not exactly near it right now
Old 09-01-2014, 10:07 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Welcome! Looks like you have a great truck to start. Getting her to stop and go are exactly the right things to do. Enjoy the ride.
Old 09-01-2014, 10:11 AM
50 Flathead f-2
Thanks I'd like to eventually get it painted professionally flat black and get a good looking wheel and tire combo and maybe lower it about two or three inches.
Old 09-01-2014, 10:54 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Welcome to FTE!
That's a good looking truck. Nice starting point!
Thank you for your service. Hope you return home soon.
Old 09-01-2014, 11:19 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
It's an honest old ride and you've gotten a great start on making it a driver. Add my welcome and thanks for your service. Stu
Old 09-01-2014, 03:09 PM
50 Flathead f-2
What is the bolt pattern for these trucks? And where could I find some wheels for it at could be newer style custom rims or originals? And also what is the overall tire diameter?
Old 09-01-2014, 03:14 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
Theyre 8x6.5. Same pattern used on ford 8 lug wheels up through 1997.
Old 09-01-2014, 03:16 PM
50 Flathead f-2
Okay thanks that helps a lot! What should I really watch for on these trucks I've never had anything like it before? And thanks everyone for the comments and thank yous!
Old 09-01-2014, 05:09 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
These trucks are pretty bullet proof. A couple things that take a bit of getting used to are the non-synchronized transmission and the really low geared rear axle. The transmission has to be double clutched or you grind the gears. The rear axle will limit your cruising speed to about 45-50 m.p.h.
There are things that can be done to change both the transmission and the rear axle gearing that change the way these trucks drive. Unless you really need a different transmission (like if you wanted to drive your truck through downtown L.A. or something) the transmission is usually fine once you learn to shift it.
The rear axle gearing is usually fixed by installing a 4.11 ratio kit available from Chuck's Trucks or by changing rear axles to a Dana 60. Since you have an F-2, your emergency brakes are on the rear axle and you have to be careful about the Dana 60 you install so you retain emergency brakes.
Old 09-01-2014, 08:42 PM
pineconeford's Avatar
pineconeford
pineconeford is online now
Knuckle Bandage Sales Rep
y
Originally Posted by 38 coupe
...... Since you have an F-2, your emergency brakes are on the rear axle and you have to be careful about the Dana 60 you install so you retain emergency brakes.
On my F2, the stock parking brake is on the transmission output shaft. If his is the same way, he won't have to consider that if/when changing the rear.
Tom
Old 09-01-2014, 09:47 PM
truckdog62563
Originally Posted by pineconeford
y
Tom
Yours is probably a late year 1951 build.
To the question on stock tire diameter, a 7.50 x 16" as was original to the truck is 32" tall. If you want radials a 235/85R16" is close. Stu
Old 09-02-2014, 01:52 AM
50 Flathead f-2
Mine has the Timken split housing is that still available through chucks trucks?
Old 09-02-2014, 02:45 AM
truckdog62563
The stock axle ratio in the Timken model 51524 axle used between 1948 and 1952 is 4.86/1. A 4.11/1 was a very rarely found optional gear set. Chuck Mantiglia of Chuck's Trucks has available a reproduction 4.11/1 ring and pinion set for this axle. I have them in my truck as do several other members. Below is a link to Chuck's web site. Stu
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
Old 09-02-2014, 03:50 AM
50 Flathead f-2
How do you tell the difference? Is there a way to tell right away without cracking into it?
Old 09-02-2014, 10:59 AM
pineconeford
If your truck sounds like Janis Joplin when you are in first gear, you have 4:86 gears.
Partke
113
03-20-2017 08:19 AM
cowjelly
21
07-06-2015 10:32 AM
MI1951f1
18
12-22-2014 03:02 AM
EcoBoosted
52
11-18-2012 07:25 PM
greenmachinejohn
77
08-04-2012 08:01 PM
Quick Reply: Starting my 50 F-2 thread
