Virginias' Unofficial September Chat Thread
#256
#257
#258
#259
If I saw a whole regiment charging me with picnic tables, I would die laughing!
Seriously though,
If it were same era tech, yeah it would be a scary sight. Thats a lot of heavy metal heading your way. The only upside is the guys were only like 4' tall back then!
Seriously though,
#260
Mine comes out easier then that Tim. But a triangular wound will never heal. Even modern medicine cant fix it very well without alot of skin grafts. If the actual running through doesnt get ya the infections sure would. And I can also shoot once it has run through 2 people. ALthough 550 grain soft lead round would probably do alot more damge then most newer rounds.
#261
belive it or not alot of the guys back then were at least 5 feet tall some taller then that. Our standard tents we use are 6'6" tall.
#263
Add to that Tim the British army would stagger the heights of the bayonets. first rank would be parallel to the ground. Second and third rank would be vertical. Thats why most battles were fought and won without very many casualties. It was about who scared the other side off the field first back then. Add to that the British military was also the best trained especially when it came to the use of bayonets.
#264
#265
#266
#267
#269
Yup, most are much smaller now. Mostly because they are more than bayonets now, they are used as utility knives, close quarters weapons and it even has a built in wire cutter in the sheath. I dont think there has been a bayonet charge since Korea. Those were still a bit longer, I believe they were garands.
#270
