12 volts at back of truck?? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-01-2014, 09:46 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
I need a constant 12 volt wire at the back bumper, is there a constant 12 volt wire in the back or should I just run one from the front of the truck. It's just for some led bed lights, will be low amp pull.
Could of swore I saw a post on this before but whatever I search for I can't find anything.
Thanks.
Old 09-01-2014, 09:50 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I don't think there is. I recall reading something and they ended up running a wire from the battery to the rear.
Old 09-01-2014, 10:22 AM
sxrfun sxrfun is offline
sxrfun is gaining momentum as a positive member of FTE.sxrfun is gaining momentum as a positive member of FTE.
I think the trailer plug has a constant 12v wire....no?
Old 09-01-2014, 10:27 AM
RM2738's Avatar
Quote:
Is it hot with the ignition off?
The OP asked for constant so I assumed he's needing hot 24/7.
Old 09-01-2014, 10:31 AM
Hmmmm..Now that sir is a good question.....I'm not sure...I'll have to go test my plug and see.
Old 09-01-2014, 10:38 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
you will need to run from the battery.
Old 09-01-2014, 10:41 AM
^^^^^^^^ What he said....Just tested and it's a switched 12v...my bad....;-)
Old 09-01-2014, 12:26 PM
bubbasz1's Avatar
Thanks for the responses, will post a picture tonight when it gets dark. My son was gracious enough to crawl under the truck to run the wire so that was nice.
Old 09-02-2014, 06:04 AM
bubbasz1's Avatar
Sorry, couldn't get a picture, just could not get it to work with the light generated. I mounted 8 led's along the top of the bed to light up the bed at night, worked as planned, mounted a push button switch to activate them, thanks for the help.
Old 09-02-2014, 06:09 AM
senix's Avatar
Bet that lights up the bed really nice. Great Idea
Old 09-02-2014, 06:40 AM
bubbasz1's Avatar
Works out nice, especially with tonneau cover on, no more flashlight to dig your stuff out.
Truck ignition dropping voltage Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-08-2015 06:09 AM
evap code 446 Mangelsen22 2004 - 2008 F150 4 10-02-2015 02:04 AM
12v constant wire dead? dustinsheeler717 6.0L Power Stroke Diesel 7 03-03-2015 09:33 PM
Ok, 6 or 12 volt vanspeed 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-21-2015 10:47 PM
Correct a mismatch ? John R. Thomas Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 04-24-2014 10:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
