a cold bog
Old 09-01-2014, 11:19 AM
gammatino's Avatar
gammatino
gammatino is offline
This dude says the same thing as my book
How to Clean and Test your IAC - FSB Forums
Old 09-01-2014, 11:21 AM
subford's Avatar
subford
subford is offline
Originally Posted by gammatino
The varible ground on the iac is blue and white and I traced backed to the fire wall before it goes in the computer. and tested there to make sure it wasnt a faulty wire, In my book they
show the positive side of the iac jumping off the fuel injectors. But I am
still only getting .01 volts at the Iac?
The 361 red wire goes to a lot of places including all the fuel injectors and the computer.
Old 09-01-2014, 11:23 AM
subford's Avatar
subford
subford is offline
He must have been reading your book and would make them both wrong.
Old 09-01-2014, 11:25 AM
gammatino's Avatar
gammatino
Why dont you jump out there and probe that 94. Laughing. Just kiding.
You mean I cant trust the holy haynes book
Old 09-01-2014, 11:28 AM
subford's Avatar
subford
subford is offline
I would not trust anything in that haynes book other than maybe to start a fire with it.
Old 09-01-2014, 11:35 AM
subford's Avatar
subford
subford is offline
Look the wire going back to the computer from the IAC will have what ever voltage on it that the computer does not ground away. It is actually a variable pulse width, the width would depend on a lot of things so no body can tell you what the voltage is at that point. It would also depend on your type of meter and how fast it is.
Old 09-01-2014, 11:38 AM
gammatino's Avatar
gammatino
Replaced it.2wice. Think I have the old one. Could swap it out.
Old 09-01-2014, 07:59 PM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
I wouldn't throw any more coin at it till you get the DTC's. Data Trouble Codes. I could be anything from HEGO sensor to low signal from EVP. From what iv'e seen of bad IAC it'll idle erratically.
Old 09-01-2014, 08:37 PM
danr1's Avatar
danr1
danr1 is offline
Sounds to me like its fine mostly questioning his readings. Looking to the IAC as possible cause of the flat spot hesitation mentioned.
Only issue I see is low engine vac, based on comment made sounds like would benefit from having the base timing checked/set.
Low vacuum reading suggests late timing, might not take out all the flat spot/hesitation complains of when cold but if it is late enough base timing to cause idle at 16hg engine vac no other cause? doing so would be a huge improvement.
Old 09-02-2014, 08:41 PM
FourXFord2's Avatar
FourXFord2
Would a bad Air Charge Temp (ACT) sensor cause cold/hot start problems?
Old 09-03-2014, 06:48 AM
gammatino's Avatar
gammatino
Maybe the timing chain? It has 5 degrees of slack in it. Right on the border
line of replace from what I understand?
Old 09-03-2014, 04:41 PM
gammatino's Avatar
gammatino
Think I found it The thermactor bybass valve 1/4 nipple was broke off. I got
some jb weld and glued it. I HOPE IT HOLDS.i DRILLED IN ALITTLE AND COUNTER SUNK IT.
i USED THE JB WELD CAUSE OF THE HEAT. i DONT KNOW IF IT GLUES PLASTIC.
i LL LET IT SIT OVER NIGHT AND PLUG IT IN. wHAT A PAIN.hOPE THATS IT?
almonyspm1
04-14-2013 02:05 PM
hotweekend
01-29-2013 07:12 AM
big60
10-20-2008 05:31 AM
shooter05
08-20-2007 10:48 AM
AQUARIES1
Computer Chips & Tuners
09-25-2004 06:46 PM
Quick Reply: a cold bog
