Why shouldn't I buy this '54 F500?? Edit: Too late, I bought it!!!
  #61
Old 09-07-2014, 09:35 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
Looking at the intake it looks like the middle cylinders were hotter than the rest.
  #62
Old 09-07-2014, 10:25 AM
38 coupe's Avatar
38 coupe
38 coupe is offline
  #63
Old 09-07-2014, 10:32 AM
SwOkcOffRoader
I'm already waiting on replies from the OKC ads. The one in Texas is a great deal, but I'm not sure a can afford the motor and the drive till after payday.
  #64
Old 09-07-2014, 10:33 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
That is where the exhaust is routed when the engine is cold to warm the intake manifold. If the butterfly heat riser on the passenger side manifold is stuck closed the manifold does get [B]extremely[/B] warm.
Edit: It is normal to see the paint burned or discolored on the intake manifold in this location on a Y block.
  #65
Old 09-07-2014, 10:35 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
If you'd like, I have a '55 239 block that was running fine last May. It had a cracked head so I replaced the whole thing. Swing on down to Dallas and get it out of the wife's way! It's just the block crank rods and pistons (still assembled) but it is free if you want it. Send a PM.
  #66
Old 09-07-2014, 10:37 AM
The Horvaths
Originally Posted by raytasch
That is where the exhaust is routed when the engine is cold to warm the intake manifold. If the butterfly heat riser on the passenger side manifold is stuck closed the manifold does get extremely warm.
And that leads to cracked head on left side. Then burnt valves and the like.
Previous owner thought he tied the valve open. Instead, he tied it closed. Oops!
  #67
Old 09-07-2014, 11:18 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
What a cool truck. I hope ya keep a Y Block in it. A 292 is a heck of a truck engine.
Check out "Y Blocks Forever" web site. Maybe someone can post a link to it?
  #68
Old 09-07-2014, 11:39 AM
SwOkcOffRoader
Can't beat that offer!! If I don't find a good 292 I'll definitely hit you up!!
Good info on the exhaust, I will definitely get educated on Y blocks quickly with this one.
  #69
Old 09-07-2014, 02:03 PM
SwOkcOffRoader
The guy with 2 292s and a 312 said he would sell me a complete 292 that's out if his truck. It runs but smokes for $150. I wonder what my machine shop will charge to go thru it??
  #70
Old 09-07-2014, 02:05 PM
SwOkcOffRoader
I'm still going to tear this one down some more. Maybe a gasket set and having the heads cleaned/checked will be all it needs.
  #71
Old 09-07-2014, 09:49 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
One thing to be aware of is the use of gasket seat spark plugs in 1954. Starting in 1955 Ford used taper seat spark plugs. Just one more of the 1954 Y-block quirks.
  #72
Old 09-07-2014, 10:22 PM
55 f350's Avatar
55 f350
55 f350 is offline
thanx stu for the pic ! i still say it's far easier to put a later 292 in it instead of the oddball 239 . there was a small list of things that were different on them if i remember than any other y block , and i think i read about it here in some thread from a few moons ago .
  #73
Old 09-08-2014, 11:00 AM
raytasch's Avatar
raytasch
Believe Nothing
Just be aware of an inherent problem with the Y blocks. There is a oil passage dog leg between the deck and the head where oil tends to coke and block flow to the rockers. Cam bearings in the earlier engines can be problematic as well in they don't allow enough oil to the rockers. Even if you have your heads worked be aware oil flow to the heads could still be a problem.
  #74
Old 09-09-2014, 05:35 AM
AXracer's Avatar
AXracer
AXracer is offline
It's pretty much standard to add an outside oil tube kit to solve this problem.
  #75
Old 09-09-2014, 05:53 AM
The Horvaths
From what I recall: The early 239's cam journals are a different size than any other Y-block.
Quick Reply: Why shouldn't I buy this '54 F500?? Edit: Too late, I bought it!!!
