Odometer Issues - please help. - Ford Truck Enthusiasts Forums
Old 08-31-2014, 02:57 PM
rickcroom's Avatar
rickcroom rickcroom is offline
rickcroom is starting off with a positive reputation.
I have an 04 F150 Heritage. For the last couple of months the odometer has been acting funny. Sometimes the LEDs will light up and display the mileage but most of the time it will not. When it does I can tell that it is still adding up the miles so that part is working . The problem seems to be in the LED readout.
One mechanic told me that I would have to take out my entire display and send it off for repair. The repairs could cause my odometer to go back to 0. This doesn't seem right to me.
Thanks in advance for your help.
Old 08-31-2014, 03:09 PM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
....If you can solder..you can fix it..There is a thread here on the board about how to perform the fix. It is a cold solder joint on the display. I took mine apart and fixed mine about 5 yrs ago...Works perfectly now!
Old 08-31-2014, 06:37 PM
rickcroom's Avatar
Quote:
Originally Posted by 96f150 View Post
....If you can solder. you can fix it. There is a thread here on the board about how to perform the fix. It is a cold solder joint on the display. I took mine apart and fixed mine about 5 yrs ago...Works perfectly now!
Thanks found the thread for repairing. Here is the link in case someone else is looking.
http://www.ford-trucks.com/forums/19...lem-fixed.html
Old 09-03-2014, 06:51 AM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Sometimes on, Sometimes off or even yet, i get a screwy flashing all sorts of digits .
If i smack the dash it will calm down. Been that way for almost 2 years.
It records the mileage ok, It is just the display. I saved the link on the repair also for when i ever decide to tackle this.. Everytime i go to do it, Somthing else pops up and i put this project on hold again.
Old 09-03-2014, 08:59 AM
acogoff acogoff is offline
acogoff is starting off with a positive reputation.
If you use a good magnifier, you will probably find that most of that line of solder joints shown in the instructions need to be redone. Mine had 5 with cracks so just did all of them, takes but a few seconds with the soldering iron.
Old 09-05-2014, 01:32 PM
hill folk hill folk is offline
hill folk is starting off with a positive reputation.
Mine is doing the same thing. Got to fix it one day. Thanks for the link.
Old 09-05-2014, 02:16 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
great job finding the thread for fixing this. I'll sure remember this if mine ever goes crazy.
1997 f150 odometer not working TheProfessorofTOOL 1997 - 2003 F150 5 07-21-2015 07:49 AM
2004 Odometer/Temp LCD Backlight wtourvil 2004 - 2008 F150 25 02-28-2012 08:43 AM
odometer display lights intermittantly dartguy699 Explorer, Sport Trac, Mountaineer & Aviator 5 07-21-2008 11:04 AM
odometer "error" display dharmabum 1987 - 1996 F150 & Larger F-Series Trucks 2 02-15-2005 04:10 PM
2000 Expedition Odometer Display Goes Out JeffGray 1997-2006 Expedition & Navigator 6 09-04-2003 11:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
