What axels in my F250?
Hi all,
Just bought an 03 F250 XL 6.0L diesel, 4wd, 6 speed manual. Going to pick it up on Tuesday. Just wondering what axels this truck would have? I assume it would be either Dana 50 or 60 front, and a Sterling of some variety in the rear. Probably 3.73 gears. Can anyone confirm? Would I have LSD in the rear?
check the tech folder, post # 9 for some axle codes:
https://www.ford-trucks.com/forums/1...r-and-faq.html
Extra info just fyi:
Front Axles.
99-04 DRW F350 - all D60
99-01 F250, F350 - all D50's
02-04 F250, F350 - all D60's
00-05 Excursions - all D50's
Rear Axles.
99-04 SRW F250/350 Sterling 10.5 FF Disc brakes
05-07 SRW F250/350 Sterling 10.5 FF Disc (Wider Track Width)
DRW rears were D70s & D80s as I remember but I don't recall the model year breakdown.
Front Axles.
Rear Axles.
Front Axles.
Rear Axles.
Front Axles.
Rear Axles.
good stuff, I was told that all 99-2003 F250s had the dana 50. Either way, if its a D60 it should have '248' cast somewhere on the back of the diff.
Here is the casting on my D60. I have an 02 CCLB w/ 5.4. If it's a D50, I believe the number will be 229.
You can also check this web site with the vehicle VIN. It will tell you ALL of the options on the truck. Click vehicles at the top and then enter your VIN.
FordEtis home page
Here is what it gave on mine. You have to expand the little arrow to see all of it after the search.
FordEtis home page
Primary Features
Build Date: 03.06.2002
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Double Cab (3/4 Door)
Version: 250 Series
Engine: 5.4L Modular SOHC V8
Transmission: E4OD(4R100)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: True Blue
Minor Features
Medium Flint
With Leather Trim
Nudo
Blocker Beam-Underbody Front End
With Tailgate Lock
With 8' Styleside Box-Steel
With Load Box Edge Protectors
172"/4369MM Wheelbase
Lariat
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Security Lock Group
With Camper Pack
Complete Vehicle
8800 LB. GVW
Less Appearance Group
Less Cold Weather Group
With Off Road Appearance Pack
With Power Equipment Group
Less Ambient Temp/Speed Pack
With On-Board Diagnostic System
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 2 Ton Mechanical Jack
Less Warning Display
Less Fire Extinguisher
Less Tool Kit
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Sliding Rear Window
Standard Ovrhed Console & With Rail
Less Floor Mounted Console
Fixed Foot Pedals
Less Front Floor Mats
Less Rear Floor Mats
With Carpet Floor Covering
Sunvisor - Dual Drv Illuminated
Sunvisor - Dual-Pass Illuminated
With Level 4 Door Trim Panel
With Sound Insulation Pack Level 1
Less Exterior Sun Visor
With Bright Front Grille
With Lower Body Moulding
Less Rear Window Protector
With Side Auxiliary Step W/O Lights
With Dipping Rear View Mirror
Dual Sail Telesc TT Power Mirror
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Seat Belt Warning Light
With 2nd Row Bench Seat - 3 Passngr
With Driver 6 Way Pwr.Seat Adjuster
With Pass 6 Way Power Seat Adjuster
Trailer Tow Prep Pack
Less Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
Power Locks W/Auto Lock - Relock
With Door Entry Remote Control Unit
Rocker Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
Less Passenger Air Bag Deactivation
With Frame Mounted Tyre Carrier
With Steel Spare Wheel
With Standard Rear Shock Absorbers
With Single Rear Wheels
7.0 X 16" 6 Window Aluminium Wheel
LT265/75R-16E A-S BSW Tyre
With Conventional Spare Tyre
Less Wheel Covers
With Bright Wheel Hub Cover
Less Immersion Heater
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
With Heavy Duty Rear Springs
With Rear Stablizer Bar
3.73
Less Rear Axle Limited Slip Diff
Ford Axle Type
Rear Axle/Wheel Lube-Mineral Based
With Mono Beam Front Axle
With Catalyst
Less Exhaust Pipe Extension
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
With Standard Transmissn Oil Cooler
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
With Skid Plates
With Mid-Ship Fuel Tank
With Non Locking Fuel Cap
For Unleaded Fuel
Less Gaseous Prep Pack
Less Diesel Fuel Content
With Steering Damper
With Tilt Steering Wheel
Leather Steering Wheel
With Speed Control
With MPH/KMH Speedometer
With Reverse Proximity Sensor
Less Engine Immobiliser
Heavy Duty Battery
Heavy Duty Alternator
Elect Prem Stro/Cass/Disc/Clock
Less Radio Pre-Equipment Pack
With NAAO Radio Frequency
High Front Lamps W/Signature DTRL
Less Daytime Running Lamps
With Front Fog Lamps
Roof Marker/Clearance Lights-Conv
Engine Compartment Light
With Dual Beam Dome Map Light
With Glove Box Illumination
With Load Compartment Lamp
Tail lamps - Level 1
With High Mounted Stop Lamp
With Automatic Headlamp Control
True Blue
250 Series
F81A-5310-AFD (5200 LB.)
F81A-5310-AFD (5200 LB.) #2
Less B&A Control Codes Issue 030388
Lt. Argent/Md. Platinum/Lt. Argent
4X4 SRW Off Road - Silver/Black
Less LPO 50S Emiss Calib Label
E4OD(4R100)
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"BS"
(-)"VN"
(-)"BO"
Version: 250 Series
Axle Ratio: 3.73
Paint: True Blue
Minor Features
Medium Flint
With Leather Trim
Nudo
With Tailgate Lock
Lariat
U.S. Sales
Security Lock Group
With Camper Pack
Complete Vehicle
8800 LB. GVW
Less Tool Kit
With Privacy Glass
Fixed Foot Pedals
With Driver Air Bag
Less Wheel Covers
3.73
Ford Axle Type
With Catalyst
With Skid Plates
For Unleaded Fuel
With Speed Control
Heavy Duty Battery
True Blue
250 Series
E4OD(4R100)
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"BS"
(-)"VN"
(-)"BO"
jgavac
08-15-2012 02:27 AM
