1956 f100 rearend - Ford Truck Enthusiasts Forums
1956 f100 rearend
Old 08-31-2014, 01:50 PM
Arkyhunter Arkyhunter is offline
Arkyhunter is starting off with a positive reputation.
1956 f100 rearend
Hello every body I have 56 rear end that I need to pull the axles.I have unbolted the flang but they still don't come out. And also it has a tag that has 41/11 is that a 411 ratio.
Thanks
Arkyhunter
Old 08-31-2014, 02:07 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
3.73
I should come off
Old 08-31-2014, 02:23 PM
Thanks for your reply.But I forgot to tell its not a 9" it has a back plate.
Old 08-31-2014, 02:54 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
You will need to use a slide hammer to pull the axles out
Old 08-31-2014, 03:12 PM
Quote:
Its probably a Dana 44, stock...
Bigwin is correct use a slide hammer or a rim with the nuts flat with the bolt, and jank it
Old 08-31-2014, 04:34 PM
thanks everyone I also have the 56 3 speed tranny & bell housing whats the newest motor that will work.
Thanks
Old 08-31-2014, 05:58 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Thanks
Arkyhunter
That's 47 divided by 11 = 3.73
EDIT. I see this was already answered.
Old 09-01-2014, 03:29 PM
Well I was hoping it was geared lower. I have all the running gear of this 1956 and I'm using it to build a tractor. But the motor was no good.Will a 60- 70 model motor work with the 56 tranny? If theres anyone in Arkansas that need some 223 motor parts your welcome to them. The bock and to pistons are bad but the rest is ok.
thanks
1992 Ford ranger 1992fordrangerman Engine Swaps 2 07-19-2015 11:48 AM
Headlight Problems tigers3535 Escape & Escape Hybrid 1 11-05-2014 12:11 AM
1990 turtle top lindasue 1968-2013 Full Size Vans 5 08-29-2014 10:06 AM
Stock seat covers maverick600 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-27-2014 11:35 AM
Who has the most Miles? Hausladen Modular V8 (4.6L, 5.4L) 25 04-05-2003 09:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
