56 Ford F-100 Door Hinge Pin - Ford Truck Enthusiasts Forums
Old 08-31-2014, 01:26 PM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
I believe the door hinge pin I am looking for is OEM B9A-5943030-A. I have found some with the last letters "AA" instead of the single "A" but I cant be sure they will work.
Does anyone have any original hinge pins with the spiral groove for lubrication on the pin shaft? I see some generic replacements, but they have no groove for lubrication and they appear to be just regular steel.
Used might work if they were tight when removed from the hinge.
Old 08-31-2014, 01:53 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
The original part number for the 53-56 door pins are:
BAAA-8122840-A - 2 23/64" long
It doesn't look like the original pin is reproduced and the 1957+ is substituted which is longer (cut to fit) and doesn't have groves.
Old 08-31-2014, 02:32 PM
Ok Nathan, I will check that out then. Maybe someone will have a used one laying around. I'm putting the original ones back in after I paint the hinges so used is ok if its tight. Thanks for the help.
Old 08-31-2014, 02:47 PM
Only hit I got on that number is the the FTE thread I just started, lol. I will try hinge pins for 57. I found a set of hinges on ebay for 1957 but I dont think they will swap out with the 56 hinges.
door hinge pins and adjustable hinges Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-24-2016 09:59 PM
51-52 F1 Door Hinges PhattRabit 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-14-2014 08:13 AM
Stock Door Hinge Pins Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-30-2014 10:16 PM
Late 80s early 90s hinge pin replacement 19704X4F250 Ranger & B-Series 2 09-26-2013 01:33 AM
Door Hinge Rebuild MNTBUGGY 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-20-2012 08:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
