6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
blue smoke f250 6.4 help!!
Old 08-31-2014, 11:15 AM
tsubaki's Avatar
tsubaki
tsubaki is offline
I have a 2008 f250 6.4, im getting alot of blue smoke , so i started to do reaserch and i found out the DPF makes the truck smoke if its bad so i check the truck the dpf removed and it has a dpf delete. So i kept reserching and it said maybe the turbo was damaged when the dpf was still in the truck i baught a brand new turbo really expensive, it got installed id rove it for 30 minutes everything looked perfect no smoke. And then out if no where it started to blow alot of blue smoke again, so i tought was if some of my injectors are bad the rings or something so i took them off took them to a place where they check them to see if there bad, wwaited like 4 days n they told me 3 of them where bad so i baught all 8 of them new. I drove it and it still blowing blue smoke! I dont k ow what else it could be my head hurts just looking at this truck. During all this i took truck to the dealer get it diagnose and they found nothing. If anyone could help !!
Old 08-31-2014, 11:55 AM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
Most likely it is your tuner...what tuner do you have? When with ford did the scan for any codes?
Ever deal with any diesels before?
Old 08-31-2014, 11:03 PM
RM2738's Avatar
RM2738
RM2738 is offline
Who put the turbo in? And who did the injectors?
fl_mudlife
11-02-2011 07:21 AM
2006powerstroke90
11-01-2011 03:30 PM
15 and 92 Dad
06-01-2011 12:55 PM
BigAlsPSD
35
02-21-2011 06:24 PM
adambomb
02-25-2007 12:05 AM
Quick Reply: blue smoke f250 6.4 help!!
