No instrument lights?
08-31-2014, 01:04 AM
on
For some strange reason my dash lights quit working, bulbs are good, I tested them. The oil, alt, and turn signal indicators all work fine. I twisted the headlight switch so it's not that I have them dimmed, they just quit.
Any thoughts?
08-31-2014, 01:11 AM
Those main harness connectors at the firewall caused a bit of grief with my 64, they get pretty corroded. Might try those.
08-31-2014, 01:32 AM
Thoughts? Yep. Sounds like an electrical problem.
08-31-2014, 09:34 AM
Quote:
Originally Posted by
Vashon Islander
Any thoughts?
Sounds like the light switch is telling you it's needing replacing.
I'd say.
Orich
08-31-2014, 11:17 AM
Have you checked the lead at the cluster or switch to make sure the switch is sending power for the dash lights?
08-31-2014, 04:17 PM
The rheostat in the switch might be worn out....
Do the lights at your heater control unit work?
08-31-2014, 06:23 PM
on
No lights at the heater controls on a 67.
08-31-2014, 06:33 PM
Instead of using Kentucky windage, how about referring to a wiring diagram?
Here you go. Click for full size.:
08-31-2014, 08:32 PM
Vashon Islander
Oops, didn't know it was a '67....
08-31-2014, 08:45 PM
on
It was the two amp fuse, pulled it, cleaned up the terminals and put it back in. Working now.
08-31-2014, 09:09 PM
simple! I am glad you figured it out.
09-01-2014, 12:35 AM
Sheez. Shouldda done that as one of the first steps of troubleshooting.
Moving on...
wagonerkl
01-12-2014 03:26 AM
Boodrow379
09-08-2013 11:22 AM
herdfan75
08-17-2010 09:12 AM
johninraleigh
05-18-2009 08:18 PM
FordPickup460
05-15-2006 11:37 AM
