52 f-1 rear fenders
Well Classic Haulers has them, but ouch $700 each!
1951-52 Ford F-100 Fender, Rear, Steel, 5152, Right
lmc truck has them for $750 each:
http://www.lmctruck.com/icatalog/fa/full.aspx?Page=26
I believed they are made by Carpenter, but they want the same price. Actually the price is reasonable compared to the cost to repair the typical rusted out ones. There are very little offered in patch panels especially for the fenders, so all patches must be hand made. It may look like the typical rust areas are simple or flat, they are not, they are compound curves with rolled wire edges that require an experienced metalsmith to shape properly. Flat patches would show like crazy and/or require excessive filler that will also show. If you are going to put 1/4" or more filler on a fender you might as well put fiberglass repros on it, same thickness or less and the FG will hold up and look better than bondo and are cheaper.
Hey Scott,
We had the same dilemma with our '50 F1. Once we sand blasted it became apparent that all of our fenders were toast - covered by an inch or more of bondo. We eventually opted for the fiberglass fenders. I was concerned that it would be that cheap fiberglass stuff from the 70's.
They are actually nice & thick & after running them for 2 years - no issues.
They aren't totally plug & play - you still have to sand them & work them a bit to get them to fit & tighten up the gaps. Very minor work. We paid $265 ea. a couple of years ago. We did go with metal running boards as I just wasn't comfortable stepping up on glass boards.
Good luck over there in Cleveland.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Scott,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Gearhead,
The wheels are my son's choice. A little flashy for me but
I went for it as it will be his truck at some point (when he's financially independent).
The wheels are from Summit - the part # at the time was 142-8865c6 - they were pricey at $200ea. I think they have come down a bit. I'll have to look at the tires - pretty low profile.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Gearhead,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
flatheadkeith
20
11-30-2015 06:18 PM
51fred
10-24-2013 01:48 PM
