95 f150 problems
95 f150 problems
got a stock 5.0 302 1995 f150 have no clue what trans or any other spec its all stock butt it runs high idle at times and times it drops down to norm idle butt when high idle trans shifts hard and throtal dont have passing speed at all times pluss no check eng on butt airbag flashes 6 fast blinks 1 long then break then back to 6 fast 1 long all the time so any one have a clue what i need to do i know wires plugs cap roter could help and plan on changing soon low on $$ lol thanks
You might want to start with your Throttle Position Sensor (TPS) That and your Idle Air Control Bypass Valve (IAC). Both are on the throttle body and both can cause erratic idle. The bypass valve can be removed and cleaned with some carb/throttle body cleaner. Chances are they're going to need to be replaced. Hope this points you in the right direction. And as for the airbag light flashing, my guess would be the airbag clock spring. Does your horn and cruise control work?
mjb1962
02-23-2001 11:29 PM
