97 7.3 replaced turbo/wont run
There is no electric pump on these trucks, only the mechanical on on the engine. Was the truck running OK before the turbo replacement? What does the fuel gauge read? The "showerhead" pickup tube in the fuel tank is known to rot off, leaving you out of fuel while the gauge shows 1/4 tank.
replace turbo
If theres no pump in tank, why do I have a fuel pump relay. Every thing I've seen and read says I do have a pump in tank, anyway the fuel bowl does not fill up. truck ran perfect before. I drove it from wa to so cal without a hitch except the last 5/6 hundred miles I starting using oil. That's why I replaced the turbo, it was sucking oil threw the seals as verified by Pure Turbos
Richard
EDT: There should be a tire valve looking thing on the side of the fuel bowl. use a tire gauge to check the fuel pressure while someone cranks it. (put the top back on of course)
this is a 97 7.3 super duty. the relay is right next to horn and 2 others. this is a factory box not a add on. watched a video on utube which showed a gut replacing clogged filter at end of pickup just past the elect pump. Are you sure you have extensive knowledge of this motor?
If you have the pump in the valley and the hoses are hooked up you have a manual pump.
Just to be sure, you have an old body style truck, Right? If it's a 97 it should be.
the NBS trucks switched to electric.
Richard
This is true. I was actually thinking about that but thinking it was just an F-450. I think the badge on the fender even says "Superduty".
The badge says "F-Superduty". The model name, as it would appear on a vehicle title, and as it is referenced in the FSM, is F-Superduty. The name of this _model_ has nothing to do with the SuperDuty _series_ of trucks (F-250, F-350, F-450, etc.) introduced in 1999. Ford does this all the time. Before they were models of vehicle, Ranger and Explorer were trim packages of the pickups. The Zephyr was a Lincoln in the '40s and a Mercury in the '70s.
The OP's profile, however, lists a 1997 F-250.
#28
#29
#30
