ABS light - Ford Truck Enthusiasts Forums
ABS light
Old 08-30-2014, 07:28 PM
autumnwyatt12 autumnwyatt12 is offline
autumnwyatt12 is starting off with a positive reputation.
ABS light
So after replacing my passenger side hub assembly I thought this would fix the ABS light but it didn't. The Explorer shifts horribly so the next option was the VSS, After that replacement was finished I cleared the codes and the check engine light us now off but the ABS light is still on ? At normal running engine temperatures the explorer still shifts hard and seems thunk, thunk down the road not as bad as before but still significant. I'm desperate to find a solution and hope it is not transmission problems any help would be greatly appreciated
Old 09-04-2014, 09:42 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
The ABS light may come on from any problems detected in the brake system. It may affect the shifting, but I think only the TC lock up; I think ABS faults will disable it.
A couple things to check:
Make sure the master cylinder is full, or the float is not stuck down somewhere.
Check the shuttle valve switch (usually on the MC); pull it out to see if corrosion is shorting it to ground. If so clean it out. Also make sure the shuttle valve hasn't actually shuttled; it can happen when you bleed your brakes too aggressively. If it did, you need to nudge it back to center.
The connectors to those switches are designed to set a fault if you try to disconnect them, so you can't try to cheat them.
Another cause is burnt out brake lights.
These are the easy checks for the most common causes.
Getting a soft "thunk" when shifting from first to second shultzaberger Ranger & B-Series 17 03-30-2016 08:47 AM
Explorer 4x4 Jerking JClarkHarris Explorer, Sport Trac, Mountaineer & Aviator 14 10-19-2015 01:55 PM
1978 F150 4WD Question Erik Jaeke 1973 - 1979 F-100 & Larger F-Series Trucks 25 09-22-2015 05:13 PM
No low Range jtyler123 1999 to 2016 Super Duty 0 05-28-2015 11:28 AM
Tow package wiring puman Aerostar 3 03-01-2015 11:16 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
