Carter YFA Carburetor Reassembly Question(s)
I am rebuilding my Carter YFA feedback-type carburetor. I have everything torn down and cleaned and a rebuild kit coming from Napa.
Please excuse my ignorance, with that, my questions.
There was a device between the carb and manifold. Actually, here's a pic:
The person before me did a "smog delete" of questionable quality. My question is, do these two pipes that were cut and bent need to be properly plugged? I am asking because I cannot budge the bolts with even the largest wrench. Right now they are soaking in PB Blaster; ready for the vise and leverage pipe if need be. The one short stubby pipe was bent but is rusted through, the other I can't tell if it is plugged or not but I tend to doubt it. I am wondering if these should be plugged for vacuum purposes.
I guess I would also be entertained by some education if someone felt so inclined to tell me what the name of that part is and what role it plays in the fuel/exhuast system.
Thanks in advance. Just for giggles, here's the disassembled carb:
The part you are playing with is the exhaust gas recirculation valve - the EGR valve, and is part 9A589 in the illustration below. Part 9D477 is "Tube (exhaust gas recirculation valve to exhaust manifold" according to the master parts catalog. I'm not sure what the other pipe is as the drawing doesn't show one. But w/o the EGR valve functioning you can just bend the pipe over to seal it. Or, you can plug the whole if you can get it out.
However, w/o EGR your carb's jetting isn't going to be quite right. It'll run, but probably not the way it should. EGR doesn't really hurt anything.
OK, the small bent pipe is rusted through; you can't see it from the angle I took the shot, but there is a hole. I can't get the bolts off. I have a 4' long or so pipe for leverage and the bolts are just rounding. The only way i am going to plug those holes is to drill and tap... equipment I don't have readily available (if at all). So my question now is... if the hole is unplugged, is that going to substantially impact running condition. If so, can the carb be mounted directly to the manifold? If either option is a no-go, maybe I should look around for part 9A598?
If the pipe you are talking about is the one from the exhaust manifold, then it can be left open if the EGR valve is both closed and not being used. You have to make sure the valve isn't leaking as you don't want air to be coming into the intake there.
On the other hand, if you aren't using the EGR valve then you can leave it off and bolt the carb directly to the manifold. If the studs are too long you may be able to pull them and replace them. Or, put spacers on top of the carb, although that'll look ..... odd.
If you look at my original photo, there are two holes (left and right) of the main opening. Below the main opening is a third hole; it leads to a threaded nut with a very short nub of bent pipe; that's the one rusted through and leaking... I suspect bringing dirty air into the intake. I am looking for a replacement but having a hard time.
Is there some kind of spacer that would plug that third hole altogether (in place of the EGR assembly), or am I imagining something that doesn't exist for a reason? I couldn't directly bolt the carb to the manifold because of that third hole.
