New location for non-OEM water temp sender
When my son had my 1997 F150 4.6L RWD, he cut a hole on the right side of the steering wheel and put a air/fuel ratio gauge which never seemed to work right. Since I have the truck back I want to put either an oil pressure gauge or a water temp gauge. As I was reading the instructions online for Autometer gauges it said that on computer controlled engines you cannot replace the OEM senders with any other. You can add an additional oil pressure sender with a "Tee Adapter Kit" but the only way possible to install a non-OEM water temp sender is to install the new sender in a different location.
If I decide to put in a water temp gauge where would be a good location to install the water temp sender?
wmiller
01-11-2008 07:33 PM
