Cab Clearance Lights
#31
on
You guys that are installing these yourself, how are you getting up there to do it? I'm not a short guy, 5'11", and I just recently did the first oil change, I had to get a stepstool to reach up to put oil in the dang truck. How are y'all getting on the roof to mount these lights?
This is the only option my truck didn't come with that I'd like to have, I'm not afraid to drill holes into the roof of my new truck, I've done dumber over the years, just seems like I'd need to build scaffolding around the truck to get up there, hahaha
Thanks
Ken
Thanks
Ken
#34
#35
#36
Does this come with the mounting hardware or do I need to go buy that separately?
Just trying to decide if I go with a Tousely Ford order ($135 +10 shipping) or if I should go with the Ebay option and get the template.
I'm not sure the template is worth the extra 40 bucks.....
Opinions?
Opinions?
#37
Opinions?
Opinions?
#38
Received 3,988 Likes
on
#39
Opinions?
Opinions?
I was looking for a paper template that located all 15 holes based on the windshield.
#40
#41
If you use a 1/2 inch knockout drill, you are actually making a hole about 3/4" to 7/8" in diameter, correct. The 1/2 inch knockout drill makes a hole large enough to fit 1/2 inch conduit. Am I thinking correctly?
#42
Sent from my Telegraph using IB AutoGroup
#44
It is easy. Just use blue painters tape and lay everything out. I used a template that I made out of cardboard to mark the hole locations and then measure again.
#45
