Weird clutch - Ford Truck Enthusiasts Forums
Weird clutch
Old 08-30-2014, 12:17 AM
Richard.Parker Richard.Parker is offline
Richard.Parker is starting off with a positive reputation.
Weird clutch
Just got a 2001 f150. The truck has 253000 miles on the 4.2 six cylinder. I have driven manual transmissions most all my life. The clutch in this truck is so weird I believe something is wrong with it. When I go to take off most of the time the truck will jump and shake and sometimes die on me. I can not figure it out to save my life. I can press the clutch in to the floor and it's a very stiff pedal. I barely have to start letting off the clutch and it will grab and start to pull. It jumps way to much and I can get the combination of gas to clutch right in order to have a smooth take off. I don't know if the truck has a new clutch in it and just needs to be broke in or if maybe something is wrong. Any insight into this would help me out.
C600 Clutch Info Zia-Lycan Large Truck 7 01-14-2017 04:31 PM
95 f150 clutch issues green_95 1987 - 1996 F150 & Larger F-Series Trucks 0 08-20-2015 07:15 PM
M5OD Noise as Clutch engages. yeahoner Clutch, Transmission, Differential, Axle & Transfer Case 4 06-24-2015 12:01 PM
Wifes Clutch or Trans just seized SnuffthePunkz Escape & Escape Hybrid 4 01-28-2015 08:13 PM
Clutch not disengaging TwoMuchMud Escape & Escape Hybrid 13 09-23-2011 02:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
