Lowering a 1950 f-2 - Ford Truck Enthusiasts Forums
Lowering a 1950 f-2
Old 08-29-2014, 02:54 PM
50 Flathead f-2 50 Flathead f-2 is offline
50 Flathead f-2 is starting off with a positive reputation.
Lowering a 1950 f-2
I know I haven't posted on here on awhile but my project F-2 is finally starting to take shape (I'll get some pics on here soon) and one thing I was considering doing but I'm still not too sure about it is maybe lowering it by two inches. I'm sure this has probably been done on an F-1 but I can't find hardly anything on an F-2. Right now it's flat black the interior is still a disaster and it's has trailer wheels on it. Does anyone have any advice or pics on a good wheel and tire combo for an 8 lug model? And also possible lowering it?
Old 08-29-2014, 03:51 PM
TireDood's Avatar
TireDood TireDood is online now
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
The best way to lower it would be to send your front axle to Sid at www.droppedaxles.com. I believe that the springs are the same dimensions as an F1, there are just more of them. If they are, you can get reversed-eye main leafs from www.classic-haulers.com. I have an F2 parts truck, and the springs look the same, but there about 2x more on the F2. If all else fails, call Sid or Classic Haulers, they are both TONS of help!
Old 08-29-2014, 08:02 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
For the F1, they recommend removing every other leaf from the spring packs. I don't see where that would be any different for an F2. Best part is that the only thing it costs is a new center pin and u-bolts after you see if you get the drop you are looking for (use the old ones for mock-up). Should soften up the ride too.
Old 08-29-2014, 08:15 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Remember the front axle is the same on the F-1 through F-3.
Old 08-30-2014, 03:45 PM
Thanks for the tips I'll get some pics posted as soon as I can!
Old 08-31-2014, 11:50 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
I think an F-2 would look kind of ridiculous lowered. It is not a small truck. The larger wheel openings would look really weird on a lowered truck...
Old 08-31-2014, 01:05 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
Quote:
I disagree
Old 09-01-2014, 02:47 AM
Quote:
Originally Posted by Gicknordon View Post
I disagree
Gorgeous truck what size tires do you have? I was thinking about the same ones
Old 09-01-2014, 02:53 AM
I disagree
Old 09-01-2014, 08:50 AM
Gicknordon's Avatar
Quote:
Not mine sorry. Its a picture i think i saved from the hamb.
Old 09-01-2014, 09:16 AM
41505379's Avatar
41505379 41505379 is offline
41505379 is starting off with a positive reputation.
Wheels
On Craigs list in St Louis, Mo. there is a set of 17" stock wheels from a Dodge with 8 lugs. The price is very good too and almost new wheels. I think they fit but don't know about the offset. They have small round holes in the wheel and are painted silver and are prices with and without centers. Anyone know if they would work on an F-2. I'm keeping my F-3 as stock looking as possible, so I didn't bite. Patrick
That pretty blue truck with the shot springs or is it overloaded. It has pretty paint.
Old 09-01-2014, 10:19 AM
That one is how I want mine done lowered that amount with that style wheels I thought about maybe some moto metals but I just don't know how that would look on it.
How to lower an f250 Soljah111 1999 to 2016 Super Duty 5 04-29-2016 06:53 AM
79 F150 4x4 Steering shaft replacement? mfhull 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-16-2016 10:01 PM
Wicked Wheel 2 Questions majorgator 1994.5 - 1997 7.3L Power Stroke Diesel 16 05-15-2015 06:32 AM
20's on a 1960 f100 Embflyer 1957 - 1960 F100 & Larger F-Series Trucks 8 02-12-2014 06:46 PM
Lowering an E-150 vntgtrk 2004 - 2008 F150 0 04-22-2011 12:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
