Diluted engine Oil with Diesel
Old 08-29-2014, 12:16 PM
jtec's Avatar
jtec
jtec is offline
hi I got a 05 6.0 that came to the shop and it is mixing the engine oil with diesel fuel I already changed the injector orings nipple orings and still have the problem any ideas would be greatly appreciated thanks
Old 08-29-2014, 12:31 PM
Runs-wifey's Avatar
Runs-wifey
Runs-wifey is offline
Did you do the top Injector o-rings?
Here is one we had in the shop back in march ...
https://www.ford-trucks.com/forums/1...-you-guys.html
Old 08-29-2014, 04:21 PM
jtec's Avatar
jtec
jtec is offline
when you say top injector oring you mean the one where the oil rail nipple goes right
Old 08-29-2014, 04:26 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Time for a injector leak test. Sorry, got my tests mixed up
Old 08-29-2014, 08:16 PM
jtec's Avatar
jtec
jtec is offline
How do I do an injector leak test?
Old 08-29-2014, 08:26 PM
Rusty Axlerod
Pull the valve cover and flip the key on so the fuel pump will run. Don't crank it over. Or if it's an option on your diag equipment, command the fuel pump on. If you watch the video Runs-wifey posted above you can see what you'll be looking for. Fuel leaking from the offending injector(s) will be visible.
Old 08-29-2014, 08:29 PM
jtec's Avatar
jtec
jtec is offline
Oh Ok thanks I already did that test no fuel leaking there any other troubleshooting I can do?
Old 08-29-2014, 08:53 PM
Rusty Axlerod
Were getting to the limits of my skill/experience level here but the fuel supply is separated from the crankcase until it gets past the banjo bolts on the front of the cylinder head, so the leak would have to be after that point (somewhere in the cylinder head). The fuel supply passages are cast (machined) through the head to the injector cup area. So if the fuel isn't coming up from around the injector and mixing with the oil there, it may be leaking into the cylinder around the injector cup and then around the rings into the crankcase. I think I have read a cracked head can leak fuel into the oil system as well. Short of pulling the heads to visually inspect, if a bore scope is available, inspecting for an unusually clean piston/combustion chamber or fuel puddling in the piston may shed some light on the subject.
Hopefully one of the Techs check this thread and offer some more specific info for you.
Old 08-29-2014, 09:03 PM
jtec's Avatar
jtec
jtec is offline
Thank you very much Rusty I would check with a borescope and see what I find
Old 08-30-2014, 02:04 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
The other way that Anthony (run6.0run) Julie's hubby came up with would also work.
It involved draining the oil and then placing a catch pan under the open drain
and running the pump. The to isolate sides ha had a block-ogg tool he made
so that he could pressurize only one side of the fuel system at a time.
Sean
Old 08-31-2014, 09:54 PM
Super Duty Service's Avatar
Super Duty Service
Super Duty Service is offline
Former Vendor
You got it Sean,,, that's the test Julie was referring to. Guess she should've been more clear. If you drop the oil,, run the pump,, and no fuel,, then you don't have a leak. Otherwise,, you didn't wait long enough with the pump running.
Old 08-31-2014, 09:59 PM
Super Duty Service
Former Vendor
Negative---- That would be the air test,, that test has nothing to do with fuel.
Old 09-04-2014, 07:48 PM
Rusty Axlerod
Hey jtec! Have you made any progress with this?
Old 09-10-2014, 02:46 PM
jtec's Avatar
jtec
jtec is offline
I'm doing the air test right now, I'm getting air coming from the 2 oil return holes on the injectors is this normal?
Old 09-11-2014, 11:46 AM
jtec's Avatar
jtec
jtec is offline
just bumping the thread to see if anybody has any ideas thanks
Quick Reply: Diluted engine Oil with Diesel
