Looking for a cheap exhaust for a 2001 V8 Lariat - Ford Truck Enthusiasts Forums
Old 08-29-2014, 08:38 AM
cronos1013 cronos1013 is offline
cronos1013 is starting off with a positive reputation.
I have a 2001 F-150 V8, extended cab, 8 foot bed and my exhaust rusted out just in front of the muffler, so to ease my wife's complaints I have agreed to fix it (it really sounds pretty cool now sadly).
Does anyone know where I can buy (cheaply) a new pre-bent exhaust pipe for that thing? I don't have access to a ton of tools to make my own, but I figured I was gonna swap my rusted out pipe and muffler (the cat is good and was recently replaced) with a cherry bomb style or other similarly inexpensive muffler, but I'm at a loss for where to get a pre-bent exhaust pipe without spending hundreds.
I drive this thing under 4000 miles a year so whatever I put in there isn't going to see a ton of use, so I want to keep it as inexpensive as possible.
Thanks!!
Chris
Old 08-29-2014, 10:20 AM
ryoken31 ryoken31 is offline
ryoken31 is starting off with a positive reputation.
I'm in the same boat where my exhaust has rusted and broke off and my muffler kinda looks like Swiss cheese. The best deal I've found is summit racing makes a cat back kit for 200 bucks. You could probably swap out the muffler for a Magnaflow or something to make it sound a little more kick ***. If anyone else knows a cheaper alternative I'd be interested in hearing it too. For the moment I bought a coupler at Canadian Tire and connected the broken pipes back together. Cost 15 bucks for that and the clamps.
Old 08-29-2014, 01:00 PM
Quote:
OK, so I did some mickey mouse guestimating...and I think I have found my solution, but I've got to do some measuring this weekend to see if it will actually work.
In my case, the cat is good, so I'm going to cut off the exhaust after it, then install one of
THESE THESE
along with a cheap
Cherry Bomb glasspack Cherry Bomb glasspack
and just figure something out for a midpipe between the cat and the muffler (I think it's just a short section of straight pipe.) My goal is to keep this whole repair around 100 bucks, but if it looks like I'm SOL, I might just pick up that Summit Racing kit.
Chris
Old 09-01-2014, 03:50 PM
skidmarks82's Avatar
skidmarks82 skidmarks82 is offline
skidmarks82 is starting off with a positive reputation.
Junk yards??? Maybe - might be able to find a whole truck for that too with one .
Old 09-03-2014, 09:10 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
is it okay to buy the cherry bomb muffler and put a turn down on it?
Old 09-05-2014, 12:30 AM
goodoleboy80 goodoleboy80 is offline
goodoleboy80 is starting off with a positive reputation.
Quote:
YES. I have a flowmaster with turn downs. would have used cherry bomb but already had the flow.
Can't get this line in. Right front brake line. Salty Dog 1967 - 1972 F-100 & Larger F-Series Trucks 13 01-28-2016 10:36 AM
Front fuel line installation help! 79 F-100 scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-31-2015 01:11 PM
pre-bent brake lines? cjben 1987 - 1996 F150 & Larger F-Series Trucks 7 08-25-2015 05:56 PM
79 F-100 Fuel Line options scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-12-2015 02:11 PM
Installing New Hooker Dual Exhaust System (problem) Indy443 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-10-2014 09:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
