1959 F100 4x4 Clutch overhaul in truck?
Old 08-29-2014, 12:12 AM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
I never thought of that!
this is bringing back memorys.... When my dad had the Buick 322 & the 6cyl clutch, he insisted on starting in 2nd gear often, since he had the power. Because of that, we replaced the clutch about every 6 to 10 months. Seems we got it down to about 2 hours each time. Granted, we did not have the 4wd or the rear mount, but I bet it would be close.
Old 08-29-2014, 12:16 AM
chetspencer's Avatar
chetspencer
chetspencer is offline
Your giving me some engine support ideas, thinking outside the box.
Old 08-29-2014, 12:19 AM
cyclone-429
This is how they do the new FWD cars:
1000 Lb. Capacity Engine Support Bar
Old 08-29-2014, 12:23 AM
chetspencer
Thank you!! I have a motorcycle Jack that will get fairly close to the tranny I'm sure I can make something work.
Old 08-29-2014, 11:28 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Ive changed clutches without removing the bell housing, just remove the bottom flywheel cover and it will drop out of the bottom...
Old 08-29-2014, 11:35 AM
chetspencer
Thanks for the info, Think I can coax the pilot bearing out also? I know about the grease and Drift punch of the correct diameter(??) trick to drive it out.
Old 08-29-2014, 12:21 PM
hiball3985's Avatar
hiball3985
I've driven them out using the grease method and a bolt of the right diameter,
Old 08-29-2014, 12:26 PM
chetspencer
Thanks again, looks like it's all very doable.
Old 09-07-2014, 08:17 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Not that bad go a job if you remove the access panel from the floorboard. I thought mine being a 4x4 gave me a lot more room to work underneath. Harder part for me was aligning trans input shaft when reinstalling.
Old 09-07-2014, 08:27 PM
chetspencer
Well I got my new clutch kit in the mail yesterday, and I managed to get all of the access panel screws out. I might go for it next weekend.
Old 09-07-2014, 08:34 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Don't worry; really pretty straightforward. Just take your time & if you start to get frustrated, it's time for a beer break!
Old 09-07-2014, 08:40 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
Sweet! I bought a kit on Thursday. I'm going to pull the trans & bell housing when I do mine. I want to see the flywheel to see if it needs resurfacing before reassembling.
  #28
Old 09-07-2014, 10:07 PM
chetspencer
Good luck!! Do you have a shop manual? Your supposed to align the bell housing to the pilot bearing bore with a dial indicator.
  #29
Old 09-07-2014, 10:13 PM
chetspencer
Thanks, I've conquered every other challenge this truck has presented (still fighting my Y Block thermostat housing leak)
BradBryan58
04-20-2018 08:49 PM
cook134
10-04-2014 06:08 PM
Pwnm30rdi3
06-06-2012 06:05 AM
Imdok
10-19-2007 04:05 AM
John_1953
05-17-2007 06:09 PM
Quick Reply: 1959 F100 4x4 Clutch overhaul in truck?
