64 Ranchero w/c4 tranny - Ford Truck Enthusiasts Forums
Old 08-28-2014, 08:08 PM
JWHCMH JWHCMH is offline
JWHCMH is starting off with a positive reputation.
what year 289/302 motors will fit into my 64 Ranchero w/c4 Trans? Hope someone can help me out so I don't purchase wrong year motor. Thanks John
Old 08-29-2014, 01:44 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
5 bolt bell or 6? If it's a '64 trans, it's 5 bolt. 65 1/2 went to 6.
Old 08-29-2014, 03:39 AM
64 Ranchero
I'm new at this stuff. All I know is it has a C-4 Trans. I will crawl under it tomorrow to check. Thanks much. appreciate it. John
Old 08-29-2014, 04:02 AM
Automatic Transmission Identification Guide - FORDification.com
Check the pan pattern and other info. The C4 has a separate bell, so you could change that if need be.
All 260s are 5 bolt. 289s up til mid '65 are 5 bolt. All 302s are 6 bolt.
Old 08-29-2014, 12:17 PM
Thankyou kindly for the info and the links. John
Old 08-29-2014, 06:15 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
64 falcon/ranchero never came with the c4 trans.
64 falcon/ranchero V8 cars also only came with the 260 engine.
so if you have a 289 with a C4 in the car, it was swapped in by a previous owner, so you will have to figure out what year you have before you proceed with purchasing a replacement engine.
Old 08-30-2014, 12:44 AM
Hi! Tom,
I thought I mentioned it has a 302 in it with a C4. I'm just going to have to crawl under it to see how many bolts the C4 has in it. I am purchasing an extra engine and C4 tranny from a gentleman who pulled it to install a six in his. Its a 289 W/c4 tranny 1968 with 67,000 on it. I am excited because he gave me both for $600. THese used older engines 289 or 302 are very hard to find around here. I am in process of putting in new cam (street) and new lifters ,timing chain set, new rocker arms, new gaskets,( heads were done at machine shop) in the 302 that's in my 64. The gentleman at the machine shop ordered the cam and lifters so I am hoping its the right cam and lifters. So I am really doing a lot of video watching and reading my manual, for different steps to put it back together . Trying to do it right being a first timer. I did see a few videos of reinstalling the damper(balancer) and they used the crank bolt to pull on the Harmonic balancer. Some videos show using a tool to pull it on? Wondering if that's o.k. to do or are both ways O.K. Thanks John ( I did buy a new balancer.) P.S. I guess it doesn't matter now about the right motor beings I bought one with a C4 on it.
Old 08-30-2014, 08:23 AM
i ain't rite
the 302 in the car and the 68 289 will both be 6 bolt bell housing pattern.
68 was the last year for the 289. i have seen a few 302's made out of 289 blocks, and a few 289's with 302 stampings on the block. so the 68 may be a 302 also.
the only difference between the 289 and 302 is the rotating assembly.
Old 08-31-2014, 12:00 PM
Thankyou Tom for the info. It went into my "notes: page in my manual. I haven't picked up the 68 motor but will check the numbers when I do . Have a great day. John
Old 08-31-2014, 02:24 PM
i ain't rite
i am putting together a 89 5.0 HO for my 65 2DR HT.
i am using 73 small chamber heads with oversized valves, comp cam springs, screw in studs, and guide plates. these heads have the large spark plugs, so they look like stock heads.
i am also using a ford motorsports E-303B cam, FMS 1.7 roller rockers, edelbrock performer intake, and edelbrock 600 CFM carb..
this setup will give me 396HP at 5,000 rpm according to desktop dyno using the 351W van manifolds with stock 89 block and rotating asembly.
the van manifolds look and flow just like the 289 HP manifolds used on the falcons and mustangs.
when installed in the car, it will look just like a stock 289 hp engine
we build the identical engine 4 years ago and put it in a 36 ford pickup, it pulled 402 HP at 5,000 rpm on a dyno.
the only difference is the 36 has short tube headers.
Old 08-31-2014, 03:55 PM
Hey Tom, sounds great. Let me know how it goes. John
Saw a couple trucks today Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 7 05-01-2015 01:08 PM
64 Ford Ranchero JWHCMH Ranchero & 1961 - 1967 Econoline 1 01-22-2015 12:29 AM
64 Ranchero w/302 in it(head gaskets JWHCMH Ranchero & 1961 - 1967 Econoline 14 06-23-2014 11:30 PM
64 Ford Ranchero with 302 in it. JWHCMH Ranchero & 1961 - 1967 Econoline 25 05-08-2014 01:34 AM
1951 F1 Engine Change ?'s vans1951f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 07-21-2004 09:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
