Hard Start, hot day, almost stranded again
It only seems to do it when the light does not come on for glow plug, it is a 1994 T model. Is there anything you can add to the fuel to help pump seal better or nurse along.
I talked to Mel about a injector pump the Moose Model and he was real helpful, is his about as good as a rebuild out there? I liked him and would buy one but want a good one.
I appreciate all of you all chiming in.
From everything I have heard on the forums, these are the best out there. I have never heard a complaint on any of his products, I have on other companies. Justin has pretty much pioneered the high performance IDI. If you want the full history of it read Project Smogie It gives all of the back history and LOTS of information on the IDI engine.
on
well if it fires right up after sitting overnight then it's not fuel draining back (air intrusion.)
if the engine is warm you could disconnect the GP controller and the engine will start right up.the 87+ system won't glow the plugs on a warm engine anyway.the light might just flicker is all.gp's are just not required to start a warm diesel engine.the ip getting heat soaked just happens to happen at the same time the plugs don't need to be turned on by the controller cus that's when everything is warm.
the moose pumps may very well be good pumps.i don't personally know why they costs hundreds more than say the reputable shops such as thedieselstore,usdieselparts,several authorized stanadyne dealers etc. if you know the reason(s) why the moose is worth hundreds more and your satisfied with the reason(s) then go for it.
That will help a dying pump build pressure as it will increase the viscosity of the fuel, but if it is used oil the carbon in it will wear the pump quicker. A quart of ATF per tank of fuel is supposed to decrease wear on the pump.
Has anybody had a problem with the Government testing fuel and say it's Red dyed so it's off road fuel then fining them when you add ATF to your fuel?
Thanks for all the help, any input on a new pump is welcome. I have a outfit here locally who specializes in diesels and can do a turnaround locally in 24 hours or so. The guy at Moose was just very helpful but I have to send it out which is not as good but Mel at Moose was claiming his product took all day to rebuild because of the care they took when doing it.
R&D IDI performance
Just out of curiosity how does a completely worked IDI compare to a PS 7.3, I know a direct injection has advantages and also the oil pressure operated injectors would be more efficient. Correct or in correct?
The IDI makes more hp for the amount of fuel than the powerstroke and more miles/gallon when properly tuned up. It is also cheaper to build to the 400 hp range by a bit, but past that it begins to get difficult due to parts availability.
there is about 10 liters of dye per 1000 gallons of fuel, 1 quart of atf will not change the color of your fuel pre 88 glow systems use a temp sensor, late models do not. depending on circumstance's glows may be needed to start a engine that has been shut off for 1 hour, if the ip is worn it can cause the symptoms described, hold your foot on the floor when cranking.
Yep! it allows fuel to flow through the pump and cool it. The owners manual for these engines recommends it on every start as it gives it more fuel so it can fire easier.
#28
I was just out there starting it with my foot to the floor, can doing that flood it? it was acting funny and started right up cold but then died and took a few cranks to get it going again.
#29
With a gasoline engine it will flood out from being overly rich which in turn fouls the spark plug. Since Diesels dont have a plug to foul out, the excess fuel does really no harm as the unburnt fuel passes through the engine and comes out as the white smoke you see when cranking.
#30
