Dana 44 posi
Dana 44 posi
Picked up a used Dana 44 posi with 4.88 gears. Was told it came out of a dana 44 front end in a 79 bronco. Set the pinion up and then go to put the posi unit in and when it is fully set in the housing the ring gear teeth barely touch the pinion teeth. Will a dana 44 rear posi be different? Do they make different dana 44 posi units. This is a ford dana unit. I am stumped. Any ideas?
Well, I'm not always right. But when I am, I am.
Back to the thread... I wonder what happened. Spec the incorrect parts?
I recommend getting the Dana "BOM" (Bill of Material) number off the axle housing and verifying what it is and what it was originally installed in . Refer to the Dana axle reference link in the Tech Thread Hyperlink Compilation sticky.
Oxfordrider
20
10-31-2012 08:13 PM
Nick_F150
21
12-30-2006 04:27 PM
55FordLover
01-21-2002 10:44 PM
