Rear driveline ujoints
you have 2 different sizes possible
- 4 Wheel Drive
- 4-3/16 Inch Yoke
- 1-3/16 Inch Bearings
pn 330
OR
- 4 Wheel Drive
- 3-5/8 Inch Yoke
pn 331
These above part numbers have grease fitting in the yoke.
There are u-joints that have a plug in one of the cups to grease the joint. I do not recommend those. I have used them and they are difficult to grease.
- 4 Wheel Drive
- 4-3/16 Inch Yoke
pn 330
OR
- 4 Wheel Drive
- 3-5/8 Inch Yoke
pn 331
Thanks Larry. I found this deal on ebay:
http://www.ebay.com/itm/FORD-F250-F350-REAR-4X4-CARRIER-BEARING-STYLE-DRIVESHAFT-U-JOINT-REPLACEMENT-KIT/370973819812?_trksid=p2050601.c100272.m3467&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140813112422%26meid%3D71daaab64fec4d8eafa32e3a8c596501%26pid%3D100272%26prg%3D20140813112422%26rk%3D2%26rkt%3D4%26sd%3D300991084039%26clkid%3D144587818898143923&_qi=RTM1562570
For the money it is not a bad deal....Thanks for the help
Joe
Joe
- 4 Wheel Drive
- 4-3/16 Inch Yoke
pn 330
OR
- 4 Wheel Drive
- 3-5/8 Inch Yoke
pn 331
- 4 Wheel Drive
- 4-3/16 Inch Yoke
pn 330
OR
- 4 Wheel Drive
- 3-5/8 Inch Yoke
pn 331
Again......before you order them....crawl under and measure the width of the u-joint. The ones listed above are the wider ones.
Do you think you need the center support bearing? They usually are pretty durable.
Many times you can find items cheaper on eBay. The problem is how to get warranty on an item if it goes bad. Price the parts locally also.
Copy that my friend!
Do I need the carrier bearing....at this point no but it is going to be out and as a package deal I would just throw it in for good measure.
As for warranty....spicer is spicer and that part does not concern me to be honest and since I will be installing them, I know they'll be installed correctly.
Thanks for the help
Thanks for the help
Jeff64F100CrewCab
07-12-2015 10:48 PM
