Can't find your engine serial number?
Old 08-28-2014, 02:12 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
I don't remember anyone asking specifically for this, but since I have an engine on the stand I thought I'd take a picture of where the engine serial number can be found on the engine block. If you go to a parts counter at an International dealership, the first thing the usually ask is, "what's the engine serial number?"
"Why might I need to know this?", you may ask. Well, if you have the sticker on your valve cover with the serial number, and you're sure the valve cover came with the engine, you probably wouldn't need to know this.
If you aren't sure the S/N on the valve cover is correct, or you've removed the sticker and painted the valve covers all nice and pretty, the engine S/N can be found just behind the rear oil cooler mount, stamped in the iron.
Old 08-28-2014, 10:06 PM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
Thank you Pikachu, I was actually wondering whether there was a way to check that label for "truthiness"! You are such a master of the arcane yet so useful information.
Larry
Old 08-28-2014, 10:53 PM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
I have wondered if or where these motors were stamped. Is it stamped with date and serial# or just serial#? Can't read what it says in photo. Lucky for me I can still read the # on valve cover.
Thanks for posting info !!
Old 08-29-2014, 05:18 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Thank you Sparky.
BDK, I didn't notice if there's a date there. Maybe I can remember to look at it again today and see.
Old 08-29-2014, 02:01 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Many trucks also have the last 7 or 8 digits of the VIN on that stamping pad as well. That will confirm the engine is original to the vehicle......kinda useful to know at times.
Old 04-04-2017, 08:25 PM
OneLostCowboy's Avatar
OneLostCowboy
OneLostCowboy is offline
Thanx for the info!
Can you decode the 7.4JU2U?
Any meaning to the X at the end?
BigF350
6.7L Power Stroke Diesel
30
11-17-2023 06:16 AM
v8xploder
12-24-2006 02:41 PM
Rancha9
34
07-22-2004 03:55 PM
3greenfordsagain
06-08-2004 09:03 PM
bryan_johnson
12-17-2001 10:07 PM
Quick Reply: Can't find your engine serial number?
