good v. bad
Old 08-28-2014, 02:06 PM
ckleine's Avatar
ckleine
ckleine is offline
good v. bad
Are there high and low quality electronic voltage regulators ? I need one for my '82 F-150 inline six . Is there a difference between a $ 45 and $25 model ? thank you .
Old 08-28-2014, 02:17 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
There are differences in brands, but that doesn't always translate to differences in price as some places have them at better prices than others. I think Motorcraft is the best, but I'm not sure they aren't made in China any more. I bought
this one this one
a couple of years ago from Amazon and it is working well.
Old 08-28-2014, 04:48 PM
ckleine's Avatar
ckleine
ckleine is offline
I'LL GO WITH YOUR RECOMMENDATION . THANKS
Old 08-28-2014, 04:51 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Let us know how this goes.
Old 09-03-2014, 09:01 PM
ckleine's Avatar
ckleine
ckleine is offline
Got a Motorcraft GR540B regulator . put it in today . With the voltmeter connected to the battery , I have 14.6 v at idle ' between 15.3 and 15 .55 v with the headlights on in fourth gear . I'll see if it discharges in the morning .
Old 09-03-2014, 09:16 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
You still have a problem. The 14.6 is good, but it shouldn't go any higher than that. And, 15+ will boil your battery dry and cause the various lights in the truck to burn out quickly. Have you checked the diodes?
Old 09-04-2014, 04:49 AM
ckleine's Avatar
ckleine
ckleine is offline
I am going to remove the alternator today and check the diode tree after work today . I have the info on how to check , but I can't remember what I need to do . I will need to do my homework .
Old 09-04-2014, 07:31 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I wouldn't have started the engine without checking the diodes as you could fry your new regulator.
Old 09-04-2014, 06:23 PM
ckleine's Avatar
ckleine
ckleine is offline
Diode check gave me 535 ohms one way and 1 ohm the other way .
Old 09-04-2014, 06:55 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Sounds like you have a bad diode. But are you using the diode check setting on a meter as that should show a low #, like the 1, in one direction and infinity in the other. And I think 535 is too low. But, tomorrow I can test a couple of my known-good alternators to see what readings I get.
Old 09-04-2014, 07:42 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
The diode checker feature on the meter checks the forward voltage drop on the diode. Depending on the diode you will get around .7v in the forward or "conducting" direction. You will get a very high reading in the reverse direction.
Old 09-04-2014, 08:47 PM
ckleine's Avatar
ckleine
ckleine is offline
Thanks . Any new info is appreciated . I don't know what the resistance readings should be . I just know high one way , low the other .
Old 09-05-2014, 08:27 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Are you using a diode-check function or just the resistance scale? If you have the diode function you should use it. But, in any case 563 ohms is not close to infinity, so I think you have at least one bad diode.
Another approach is to check the AC voltage with the engine running. Google "alternator diode check" and you'll find some videos on checking the AC voltage. But your testing so far tells me you have a bad diode.
White gold
2017+ Super Duty
01-13-2018 08:09 AM
Frantz
2017+ Super Duty
24
07-21-2017 09:53 AM
hturner12
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
16
06-26-2015 09:29 AM
Spotty
1997 - 2003 F150
01-14-2015 04:06 PM
preppypyro
11-25-2008 09:02 PM
Quick Reply: good v. bad
