Proper alternator readings what should they be ?
Old 08-29-2014, 02:06 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by carbon coupe
Really? My numbers were measured on mine with a stock alternator. Never saw anything above 14. Of course, a year later I had to replace it.
Yeah, if I see my volts at 13.5 at idle when I first start it (after the GP's have shut off), I'll check it again to make sure i'm at 14.x at idle when I reach my destination.
I have one like this in my truck:
I have this one in my Ex, my L, and my daughters F250:
Stewart
Old 08-29-2014, 02:18 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Stewart
I kinda like that Stewart, I might have to get me one..
Old 08-29-2014, 02:27 PM
Bigpipes 35
Thanks for spending my money for me again Stewart I just ordered one from Ebay..
Old 08-29-2014, 03:17 PM
radmacks's Avatar
radmacks
radmacks is offline
I'm at mid 13s no load and low 12s under load at idle while driving the numbers run through green yellow and red lights. I'm trying to decide if I should take back this alternator and buy another one and keep shooting for 14, 13s.
Old 08-29-2014, 03:34 PM
Stewart_H's Avatar
Stewart_H
Rad, while plug in voltmeters are useful, they have their limitations.
If you're that low, you need to check the voltage output with a handheld meter directly off of the alternator.
Stewart
Old 08-29-2014, 03:43 PM
radmacks's Avatar
radmacks
radmacks is offline
I did, with two different meters. Its under performing in my opinion but tests on alternator at parts store are good.
Stewart
Old 08-29-2014, 03:46 PM
Stewart_H's Avatar
Stewart_H
Old 08-29-2014, 03:47 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Thanks Stewart, I'm going to order 1 of those to check the other cars in the household.
Good find!
Old 08-29-2014, 04:18 PM
radmacks's Avatar
radmacks
radmacks is offline
Okay so went out and started it up. Voltages are normal mid 14s and low 13s lights and fans on. Thinking I either have an intermittent problem (hard draw). I will continue to monitor it I guess.
Old 08-29-2014, 04:53 PM
Stewart_H's Avatar
Stewart_H
Double check all your ground points. Make sure they are clean and have good contact.
Also, check to make sure the ring terminal that attaches to the alternator is making good contact and in good working order. When I started having fluctuations, I thought it was my alt but it turned out to be a bad terminal end wire.
Stewart
Old 08-29-2014, 07:31 PM
Bigpipes 35
Good find!
Here is the one I just ordered Michael http://www.ebay.com/itm/12V-24V-Car-Mounted-Digital-Automotive-Battery-Voltage-Reader-Meter-Test-Tool-/111441531703?pt=LH_DefaultDomain_0&hash=item19f26ed337
Sampier
1999 to 2016 Super Duty
05-21-2017 11:06 AM
99expyTN
1997-2006 Expedition & Navigator
04-11-2014 03:22 PM
tomtoc
01-07-2008 01:03 PM
81fordf-250
03-23-2006 09:01 AM
wingit1x
Electrical Systems/Wiring
01-25-2004 02:59 AM
Quick Reply: Proper alternator readings what should they be ?
