Proper alternator readings what should they be ?
I have one like this in my truck:
I have this one in my Ex, my L, and my daughters F250:
Stewart
Yeah, if I see my volts at 13.5 at idle when I first start it (after the GP's have shut off), I'll check it again to make sure i'm at 14.x at idle when I reach my destination.
Stewart
Stewart
I did, with two different meters. Its under performing in my opinion but tests on alternator at parts store are good.
Double check all your ground points. Make sure they are clean and have good contact.
Also, check to make sure the ring terminal that attaches to the alternator is making good contact and in good working order. When I started having fluctuations, I thought it was my alt but it turned out to be a bad terminal end wire.
Stewart
Stewart
Here is the one I just ordered Michael http://www.ebay.com/itm/12V-24V-Car-Mounted-Digital-Automotive-Battery-Voltage-Reader-Meter-Test-Tool-/111441531703?pt=LH_DefaultDomain_0&hash=item19f26ed337
99expyTN
1997-2006 Expedition & Navigator
04-11-2014 03:22 PM
tomtoc
01-07-2008 01:03 PM
81fordf-250
03-23-2006 09:01 AM
