crager mag
Old 07-27-2014, 03:30 PM
colson327's Avatar
colson327
colson327 is offline
crager mag
I have a 49 f1 with stock wheels/tires. I would like to put on old style original cragar mags. Is there anything I might want to look out for?
Any comments would be welcome.
Old 07-27-2014, 03:37 PM
AXracer's Avatar
AXracer
AXracer is offline
They are reproducing a number of the older wheels including the Cragers. If buying new make sure you get the proper backspacing you need.
Old 07-27-2014, 03:55 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
if you doing a disk brake conversion on the front you may need to run a spacer between the disk and wheel. This would also require a different depth lug nut.
I have 15x8 on the rear with P275/60 and 15x7 on the front with P245/60 no clearance issues or problems incountered. CRR-29201 spacer kit on the front
Old 07-27-2014, 05:21 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Cragar makes them in the original steel and in aluminum. They have different offsets. I had the steel ones on my 56 Fairlane and switched to the aluminum as the offset difference solved a rubbing issue.
Old 07-27-2014, 06:01 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is online now
Roast em' if you got 'em
Received 3,838 Likes on 1,837 Posts
I've done the disc brake conversion on my 49 and have run Cragars. I didn't have to run a spacer, there were no clearance issues.
I've heard of other people with the disc brakes having clearance issues and have had to gently remove a little material from the back of the disc brake caliper.
Old 07-28-2014, 04:30 AM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is online now
Classic wheel on a classic truck. The stylists working at Cragar really knew their stuff. I still think they look as good as anything on the market today.
Old 07-30-2014, 05:19 AM
colson327's Avatar
colson327
So if I'm not running disc brakes, no problems? I think your truck looks great with those mags, love it.
Old 07-30-2014, 06:50 AM
nassi's Avatar
nassi
nassi is offline
Very well said.
Old 07-30-2014, 09:08 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
I had them on my 56 til I swapped suspensions, timeless styling for sure...
Added Note: the Cragars on this truck came with the unilug pattern which made it nice since the truck had a mid-fifties GM rearend in it. If you need different lug patterns then Cragars can meet those needs.
Old 07-30-2014, 02:22 PM
3golfjack's Avatar
3golfjack
3golfjack is offline
I've always loved Cragers.I went thru Summit Racing when I purchased my set. They come in what ever backspacing you need.
Old 07-31-2014, 06:16 PM
Rimrock F1's Avatar
Rimrock F1
Jeg's has a sale going right now on Cragers. Prices look OK and free shipping.
JEGS High Performance
Old 08-01-2014, 09:55 AM
bryanknie's Avatar
bryanknie
bryanknie is offline
American Racing is reproducing some old wheels now too. Torq Thrush TTQ, (google them) and in my pic. Mine are 235x60 on 7 inch up front and 275x60 on 8.5 in the rear, all 4 inch backspace with disc brakes up front, no spacers needed and no rubbing. Good pics in my Album.
Old 09-01-2014, 04:46 PM
stevekantercool's Avatar
stevekantercool
stevekantercool is offline
The Cragar SS wheel is probably one of the best looking wheels going. They look great on old vehicles. I have had Cragar SS wheels on many of my hot rods. But, they are the absolute worst piece of crap going, and I won't own another set.
Sometime in the late 70's or 80's Cragar changed their plating process, and literally, if the wheel just sits in the rain, they rust. The new plating process has created a tremendous amount of upkeep.
If you call Cragar, they'll tell you to clean them with steel wool, or have the hoops powder coated. Cragar will do nothing to fix the problem.
If you can find a set of Cragar's from the early 60's or before they changed their plating process, those might be alright.
Think twice. Good luck.
bcurtis357
08-08-2019 09:23 AM
Bruce Schena
01-01-2018 08:35 PM
GamerGirlAlice
08-14-2013 07:10 PM
oldopie
09-14-2012 09:52 AM
kooper909
12-19-2004 05:42 PM
Quick Reply: crager mag
