Rust Repair - What is required/suggestions for DIY rhinoliner
So in the next month or so I am going to delve into rust repair and patch panels for the rocker panels on the extended cab portion of my truck. I have never done this before so looking for advice on everything that I will need that I haven't thought of.
I am planning on cutting out as little material as possible. All my visible rust is in the bottom 2-3 inches of the panel, I am sure there is more in there once I cut into it. I plan on replacing from the body molding down so that way I can weld at the bottom of the molding and use that to hide any weld imperfections. I then plan on rhino lining my rocker panels all around the truck.
So once I get in there what will I need? I figured I will need a rust converter to spray around in there to prevent any more rust from forming and a good spray paint to put on top of that but I am sure I am forgetting something.
I am also looking for suggestions for a good DIY rhino liner for the rocker panels.
I used Duraliner inside my Bronco. It's stickier than the Rhino Liner (actual brand) I had sprayed in the bed of my '95 F-150, which is nice inside a vehicle because stuff doesn't slide around as much. But it's not as tough as the Rhino liner was, I've cut through it in a few places. So I don't think I'd recommend that for an exterior application like rocker panels.
The only other one I have any experience with is Herculiner, and very little with that. I coated an ammo can that I use to hold the jack in my Bronco and I coated my home made wood speaker boxes in the Bronco. Both have held up fine, but neither is a very tough application, so I don't know how well it would hold up on a rocker panel.
Do it yourself rino-liner
This is totally redneck but, several years ago I did extensive body work on my 95 F250. I just used regular undercoating but I mixed very fine sand in with it and brushed it on. It actually looked pretty good and I got a lot of comments about the rino liner. It's been over 5 years and it's still hanging in there. Now obviously there are better methods. I've thought about brushing on undercoating and spraying on the sand for a more even coat.
Thanks for the suggestions, I will have to look into those. One I ran across was spray-linings.com. Has anyone seen or used these guys?
Any suggestions for the best way to prevent rust from reforming behind the patch panel once installed or anything I need to look out for/be aware of before I start cutting?
I do whole bed skins and glue them on, I use no welding
turnkyle
41
10-05-2014 02:02 PM
69Black250
05-31-2009 08:33 PM
