81 ford fuel gauge problem - Ford Truck Enthusiasts Forums
Old 08-28-2014, 01:49 AM
Meanstreak97 Meanstreak97 is offline
Meanstreak97 is starting off with a positive reputation.
Hi, Meanstreak here with a kinda dumb question, my trucks fuel gauge has been acting up lately, I fill up my truck and it says full, then fifteen minutes later it will go down to E and stay there until I fill it up again. Any ideas on what could be wrong? I thought it could be the sending unit but I don't really have time to test anything right now. Any info is helpful :3 thanks!
Old 08-28-2014, 10:18 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
That sounds like the float is punctured, letting it fill with gas. You'll have to pull the sending unit to investigate (on the previous generations, that meant pulling the tank). If you shake the float and hear gas sloshing around, it needs replaced. The float is made of two halves of brass that are soldered together. Over time the solder deteriorates and fuel seeps in.
You'll also want to check the resistance of the sending unit with a multimeter while it's out. The fact that there is ever a point in time when the gauge reads FULL eliminates everything electrical outside of the tank.
81 Ford f100 Fuel gauge Problems Meanstreak97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-03-2016 06:49 PM
391 Ford Meanstreak97 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 12-09-2014 10:12 PM
81 Ford turn signal lenses Meanstreak97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-25-2014 07:32 AM
Headlights flickering Meanstreak97 Electrical Systems/Wiring 2 08-22-2014 08:18 PM
300 i6 performance help Meanstreak97 Ford Inline Six, 200, 250, 4.9L / 300 1 07-21-2014 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
