What type of engine cleaner to use?
I have a Jasper engine on my 92 F150. It only has 90,000 miles on it so it shouldn't be burning oil. The problem was I needed to replace the timing chain cover and so it leaked about 2 quarts/week for 5 months or so before I got it fixed. I used cheaper oil instead of the Mobile One synthetic oil I have always used during this time.
So after I fixed the timing chain and replaced all the valve cover seals I was surprised to see it was still using a quart of oil/week with every thing sealed up tight as a drum and no oil leaks whatsoever. I was using good Mobile One 30 weight synthetic oil in the engine.
My mechanic said because I used cheaper oil, I probably gummed up the piston and oil rings so that oil was being blown past the rings. He said I needed to get a engine cleaner to clean up the gummed rings.
So what type of engine cleaner should I use?
Regards,
Larry
Regards,
Larry
Well you don't want to use an 'engine flush'.
I have had good luck with Rislone in the yellow bottle. This used to be a local company (now owned by Radiator Specialties) and I've used it on and off for 40 years. I would imagine the formulas has changed a bit over the years. I use it in my high mileage and neglected Ram 1500 two years ago and it cleared up a few sticky lifters and seems to have lessened the oil consumption.
There is no magic potion...
Tried some Lucas Oil Treatment
Oh, my mechanic said there was a new product out that is only about 2 months old and he said it produced excellent results. He didn't say the name. I am waiting for his supplier to fill his order so I can get the engine cleaned. I imagine he doesn't want to tell me the name so I don't go out and buy the product to do the job myself.
Does anybody know the name of this new product?
Regards,
Larry
Yeah, I know it's a viscosity improver
I used Lucas in my OTR diesels for ten years. You have to understand it's primarily a viscosity index improver with some anti-wear additives in it. I used it to extend my oil drain intervals (along with a good oil sampling program).
It will help with oil consumption issues.
Regards,
Larry
Received 3,107 Likes
on
No oil leaks
It's using oil not leaking oil.
Regards,
Larry
on
Will change the oil and see if it still consumes oil
There was never any smoke out the pipes either. Seems strange.
Engine runs fine and I can easily reach top speed of 85++mph
Regards,
Larry
