high voltage
high voltage
1982 f 150 inline six . 4 speed manual . alternator is charging battery at 16.8 volts while i am drivng . with hi beams and blower on high . sound like a voltage regulator ? battery is new and alternator has new brushes and bearings . with no headlights and blower off , iy charges over 17 volts . if i let it sit for a day or two . theres not enough juice in the battery to even turn her over . I took the field wire off the alternator and it stopped discharging . It also won't charge the battery with the field disconnected . Is it possible that the diodes in the alternator are damaged ?
Most parts stores will only check output.
Check for backflow yourself if you have a multimeter with diode test.
Just ohming it out often won't put enough current to the diode. (depending on your meter)
A regulator is cheap, but check first to make sure yours is getting 'sense' voltage from the system.
Could be a broken wire or a corroded plug if your regulator is that style.
Not sure which alternator you have, if it's the 1G or 2G. But I just bought a rebuild kit for mine and a new slip ring for $35. New brushes, holder, springs, new HD rectifier, new slip ring, new voltage regulator. Local parts store wants $70 for a china reman 2G... I'll do it myself and do a better job at it than they do. Sounds like yours is pretty messed up.
Edit: noticed yours is an 82, so it should be a 1G. 86 was the first year for the internally regulated 2G fire hazard.
southern//magic
12-23-2007 08:20 AM
