96 Ibeam Bushings
If you have sway bars, you may want to replace the bushings for those too. Be sure to inspect the radius arm brackets, both of mine eventually cracked. Otherwise sounds like you're good to go. If it's 4x4, do the front axle u joints while it's apart (use a ball joint press on the passenger side inner so you don't have to open the diff & remove the stub shaft). When I last replaced those parts I dropped the front axle completely and used a ball joint press to do the pivot bushings. The first time I did it all under the truck and it was a bit frustrating. Also a good time for spring towers if yours are rotten. Man, it never ends!
broncoderek
05-08-2015 01:11 PM
