trim around outside of rear glass - Ford Truck Enthusiasts Forums
Old 08-27-2014, 06:45 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
I noticed a few weeks ago when I was in the bed of my truck that the black plastic trim piece around the rear window appears to be broken. it's on the left side near the top. when I look down there it looks like the brackets are broken on one side. I've never noticed any water leak back there. has anyone had this happen to them? I'd like to definitely get it fixed, but I don't think the dealer would have a listing for it anymore if it's not crazy expensive. I looked at LMC truck and there doesn't seem to be what I need on there. does anyone have any suggestions? it's a 2002 F150 Lariat Supercrew non-sliding window.
Old 08-27-2014, 10:36 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the window unit has studs on its frame and it bolts to the rear of the cab with nuts on the inside (behind all the plastic trim and head liner. The plastic trim also has studs and bolts on to the cab wall around the glass. The trim has nothing to do with sealing out water, and nothing to do with the window.. It is "trim" only. There was a post a couple years ago with some photos on how to remove... You pull off the plastic post covers behind the seat, then pull the headliner down and inch or two to get to all the nuts.
Old 08-27-2014, 10:37 PM
steve(ill)'s Avatar
Old 08-28-2014, 07:32 PM
Dr. Dirt's Avatar
thank you steve(ill). I will definitely look into this
Old 08-29-2014, 06:26 PM
Marty N Debbie Sapp's Avatar
Marty N Debbie Sapp Marty N Debbie Sapp is offline
Marty N Debbie Sapp is starting off with a positive reputation.
You will have to remove the window first to get the trim off. The trim is over $400.00 Go to your local scrap yard.
Old 09-01-2014, 07:52 AM
Rickster123 Rickster123 is offline
Rickster123 is starting off with a positive reputation.
I have the sliding glass window in my 2002 F150, and the drivers side trim has come loose. When I first bought the truck, same issue developed. Took it to the dealer, warranty covered it. It's not warranted anymore 161,000 miles. It seems like there should be a hook of some sort inside but I don't see anything like that. It doesn't leak,so it's on my" to do" list that gets longer all the time. I have a feeling auto carwashes might have something to do with it?
Old 09-01-2014, 11:00 PM
steve(ill)'s Avatar
How about squirting some black RTV behind the trim and pushing it back into position ? Not perfect, but save about $395. !
Old 09-03-2014, 06:50 PM
Dr. Dirt's Avatar
Quote:
that's an option for right now, but eventually I will get it fixed.
Quote:
this sure is on my "to do" list also.
Horror stories about rubber pieces for these trucks. Serfbored 1967 - 1972 F-100 & Larger F-Series Trucks 18 01-15-2017 02:44 PM
how to install rear windoe trim in a 1974 gumshoe 1973 - 1979 F-100 & Larger F-Series Trucks 12 09-28-2016 10:34 PM
rear window chrome trim '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 0 08-09-2015 07:01 PM
Rain leaking into rear passenger/glass window dtingle89 2004 - 2008 F150 3 08-08-2011 02:14 PM
Window keeps falling down! Cant find part! Help? rwdfan 1987 - 1996 F150 & Larger F-Series Trucks 4 04-23-2011 04:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
