Help Identifying rubber. - Ford Truck Enthusiasts Forums
Old 08-27-2014, 02:43 PM
Aarons54f100's Avatar
Aarons54f100 Aarons54f100 is offline
Aarons54f100 has a good reputation on FTE.Aarons54f100 has a good reputation on FTE.Aarons54f100 has a good reputation on FTE.
I acquired several new pieces of rubber for my truck when I purchased other used parts. I believe I know what some are but they were not labeled. You guys probably know for sure so I figured I would ask.
Cab Skirt?
Rear window?
Front window?
Old 08-27-2014, 04:00 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
The top one is fender welt, the second is the headliner retainer, third is cab skirt, forth is rear window, fifth, you got me.
Old 08-27-2014, 04:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Fifth one looks like 48 - 52 windshield rubber with groove for stainless trim. But it should be one-piece molded.
Old 08-27-2014, 09:09 PM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
Not mine, but Trojans is always a good choice.
1954 f100 Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 284 01-29-2017 10:40 PM
Door Alignment. Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-30-2016 04:28 PM
What kind of booster. Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-24-2016 04:17 PM
Coolant leaks from ontop of thermostat+water pump how to fix? Theos92vr4 1987 - 1996 F150 & Larger F-Series Trucks 2 10-28-2015 10:03 AM
Sandblast the body or no? Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 06-06-2015 11:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
