How do you tell a the difference ?? - Ford Truck Enthusiasts Forums
Old 08-26-2014, 10:39 PM
Smully00 Smully00 is offline
Smully00 is starting off with a positive reputation.
How do you tell the difference between a Windsor and a Cleveland block?
I have a 71' f100 I know it has a 360ci in it.But which one ? Or is it neither?
Old 08-26-2014, 11:04 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
360 is neither, 360 is an FE motor. The cleveland was a 351. Never a truck motor either.
Old 08-26-2014, 11:36 PM
However, if you wish, I can go deeply into the cleveland engines. I think they are one of the best engines ever.
Old 08-27-2014, 05:59 AM
f100today's Avatar
f100today f100today is offline
f100today is gaining momentum as a positive member of FTE.f100today is gaining momentum as a positive member of FTE.
Yep, you already identified it in a sense. You have a FE360. Then there is a 351 Cleveland or a 351 Windsor. And none of the parts from the latter two will work on your FE that I know of.
Old 08-27-2014, 08:32 PM
There is also the 351M, but that didn't come around until mid 70s.
FE engines are all very much alike. 390 and 360 are basically identical in every aspect except crank.
Old 08-28-2014, 09:10 AM
Okay after researching the web I found out a little about the FE engine. I know now what the "FE" stands for . Ford/Edsel engines are what ford used in their light duty trucks. My question now is it worth the time , energy and$$ to rebuild one? I'm not after huge HP but would not mind a little extra get and go. Any thought on what direction I should go?
Old 08-28-2014, 10:07 AM
quinletc's Avatar
quinletc quinletc is offline
quinletc is starting off with a positive reputation.
You can (relatively) easily turn your 360 into a 390 by swapping out the crankshaft and rods.
The other most-commonly mentioned upgrade for these engines is exhaust headers and dual exhaust. The factory manifolds and exhaust don't let the engines breathe as well as they are able.
Old 08-28-2014, 10:26 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
FE = Fu#*ing Expensive
Great motors but pricey to rebuild compared to 289/302/351w
truck is already set up for the FE better to leave it and rebuild , swapping in a SBF will end up same money just spent on different parts (trans ,perches,driveshaft....etc)
Old 08-28-2014, 09:29 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I've built a 360 with good results, it was just a gas hog so I went diesel instead.
Cast iron S code 4BBL intake, dual exhausts, Delta mid-range torque grind cam, and advanced the cam timing 4*. A Holley 4160 600cfm carb, DSII conversion, and a few other minor tweaks rounded out the build. That thing was great, it did 65-70 down the freeway with 9k behind it with room for more, it just topped out at 12mpg. I had about $1200 into the engine plus my time.
What engine is what? ol'blue77 1973 - 1979 F-100 & Larger F-Series Trucks 14 05-31-2016 05:43 AM
351 1994 - Windsor, Cleveland on Modified ? JRS2 1987 - 1996 F150 & Larger F-Series Trucks 4 06-12-2015 01:25 PM
Windsor vs Romeo? Redneckryder 1997 - 2003 F150 6 11-08-2014 09:24 PM
351 cleveland or 351M or 400 Bob Crain 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 46 11-14-2012 08:00 PM
Including pictures in posts Beanscoot Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 05-22-2007 12:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
