Squirrely Steering '59 F100 - Ford Truck Enthusiasts Forums
Old 08-26-2014, 09:18 PM
timinbovey's Avatar
timinbovey timinbovey is offline
timinbovey is starting off with a positive reputation.
Bear with me as a truck newbie with all these probably obvious questions to those more used to these vehicles!
Been driving the '59 quite a bit the last week or so and mechanically she's pretty good indeed. About the only issue I really have is the steering/handling. At first I figured I just wasn't used to driving a 55 year old truck, but darn it, it's just to squirrely to be safe as is, near as I can tell.
it's not like it wanders so much -- well, maybe -- hard to describe, but you really have to "aim" it and keep on it to keep it on the road. Once I get in a groove it's OK until I hit bumps or an uneven part of the road, and I have to kind of "horse it around" curves in the road -- no simply turning of the wheel. It just can't be right.
I took it to a shop just to have 'em get it on a hoist so we could see if there was anything obviously worn out. Tie rods, pitman arm, etc. all seemed tight with no slop or wear. But these were young guys who couldn't figure out how to start it (couldn't find the left sided ignition switch) and could barely drive a stick. So they really didn't have a lot of experience with anything this old, but I know the gal who owns the shop and they checked it out for free. So it gave me a good chance to get under it and poke around a bit without laying on my garage floor!
Now, a few years ago I had a'64 Corvair -- the only other car I've had with a steering box. And it was pretty loose when I got it and I replaced the steering box with a rebuilt and it was much better. Are the odds here that I need steering box work? Or are there other things I'm not thinking about or aware of? Are there things that need testing with a technique that young guys aren't experienced with?
Thoughts, comments, advice appreciated!
Tim in Bovey
Old 08-26-2014, 11:45 PM
59f100mike's Avatar
59f100mike 59f100mike is online now
59f100mike is starting off with a positive reputation.
Has the truck been lowered?
Old 08-27-2014, 02:44 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
welcome Tim
have you checked for play in king pins?
Old 08-27-2014, 05:58 PM
timinbovey's Avatar
The guys at the shop I took it to didn't even know what king pins are! I know, but have never worked on them. I've got a buy with a little shop with 45 years of experience who knows what king pins are, and is familiar with older vehicles, so I'm gonna get it into him and see what he thinks.
And no it hasn't been lowered. However the back seems high and the fella who sold it to me thought it had some sort of over load, or heavy duty, or towing, or camper special extra springs in the back. I'm going to try to stick a photo in here, side view. It looks more level here than on the street due to the cement pad at the front of the driveway.
Tim in Bovey
t does look like it's got a hell of a lot of leafs in the back springs.
Old 08-27-2014, 06:37 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Great looking truck. Don't be surprised if the steering box is worn out, very common problem and they where a crap design from the factory to start with..
People will start telling you to replace it with a more modern design..
Old 08-27-2014, 06:43 PM
timinbovey's Avatar
I'm already half expecting it to be the steering box. Went down that road with my Corvair years ago. I DO NOT want to convert to modern power steering. Is there a relatively simple modern replacement? Or for that matter I'll bet the parts to rebuilt it are available. What are the odds there's a place I could buy a rebuilt and just replace it?
Tim in Bovey
Old 08-27-2014, 07:02 PM
Danleig's Avatar
Danleig Danleig is offline
Danleig is starting off with a positive reputation.
Here is where you can get a rebuilt box, Classic Performance Products in California:
Classic Car and Truck Brake, Steering and Suspension Parts
Old 08-27-2014, 07:50 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Beautiful truck, I like the bed rails. If the rest of the front end hasn't been replaced it probably needs it as well as rebiuld the steering box. Just a little wear in each connection point adds up when you put them all together and go barreling down the road.
Old 08-27-2014, 10:12 PM
my 66 my 66 is offline
my 66 is starting off with a positive reputation.
With the truck on flat grd take the steering wheel and go from left to right without moving the wheels. Under 2" of play should be ok. Pull the truck forward and stop slow. Check toe end. If it is toed out set it with at lest 1/8 to 3/16 toe end. Test drive, may help, if not its rebuild time.
Old 08-28-2014, 07:58 AM
hiball3985's Avatar
Quote:
Tim in Bovey
I understand not wanting modern power steering, I still run the original box. I rebuilt mine in 1975 and about 5 years ago I had to only replace the 2 bushings to get it back to normal.
Old 09-03-2014, 06:35 PM
timinbovey's Avatar
My "real" mechanic got a chance to check out the truck this morning and the verdict on the steering is worn drag link and worn out steering box. About what i expected actually. no trouble ordering a new drag link. But what about the box?
I followed the link above to Classic Performance Parts where they have a rebuilt box listed on the web site, trying to order one online didn't work. When they didn't answer my email I called them and was told they don't have them to send out "exchange", I have to send mine in to be rebuilt and wait for it to come back. (Even though their website says to add $100 if you're not sending in a core). Well, I don't really want to do that as the truck would sit at the shop for a couple weeks waiting for all the shipping and rebuilding time. My mechanic says he can rebuild it for me if I can get the parts.
So the two questions are: Does anyone sell a complete rebuild kit with all we need in one simple order, or do I have to get parts here and there? I'd prefer to put everything new into it possible as long as it's apart rather than just fixing it up. Or does anyone know of anyone else who might sell an original style rebuild unit ready to put in?
Tim in Bovey
Old 09-03-2014, 07:27 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Tim in Bovey
I have used box I took out of my truck when I did power steering.. No column. I cut it off to use my shaft and wheel for my application. PM me if interested. Rebuild mine and swap them out.
Old 09-04-2014, 01:10 AM
Sundance57 Sundance57 is offline
Sundance57 is starting off with a positive reputation.
Hi Tim: I have a stock steering box with column pulled from my 57 it worked just fine. I installed Toyota power steering. Let me know if you need it, just pay for shipping Gary
Steering box replacement jplinville 1987 - 1996 F150 & Larger F-Series Trucks 19 09-26-2016 05:07 PM
Excursion Towing agallant80 Excursion - King of SUVs 26 07-24-2015 09:40 PM
Bought my '59 in Sept. and the learning curve is STEEP! jsta 1957 - 1960 F100 & Larger F-Series Trucks 6 12-20-2013 08:10 PM
'06 F250 new tires now suspension issues? frankegd 6.0L Power Stroke Diesel 11 09-12-2013 11:13 PM
Squirrely Steering in 97 Expedition alaskaexpy 1997-2006 Expedition & Navigator 9 09-25-2005 05:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
