Sharpie saves the day! - Ford Truck Enthusiasts Forums
Old 08-26-2014, 04:13 PM
cgrutt cgrutt is offline
cgrutt is gaining momentum as a positive member of FTE.
Figured I'd change the fuel filter in my '05 F150. Seemed easy enough. Popped the old filter out of the bracket, used a screwdriver to release the rear clamp and then tried to use the little plastic tool that comes with the filter to release front clamp. No luck. OK, so what to do? Figured I'd cut the pipe (on filter) so I could see inside the quick release clamp and use a screwdriver or awl or something else to release the clamp. No luck. Now I'm stuck with out a fuel filter and need to pick up my son at camp, lol. Did a quick search and found this video, which was very helpful.
www.youtube.com/watch?v=hkZRSMGqQ0E
Cut the cap off a sharpie about 3/4" long, slid it over the cut pipe, pressed it in and it released the filter tube right away. Pressed on the new filter and was off to pick up my son on time, lol...
Anyway, going to order the right tool so I have it next time, but figured I'd post this in case anybody ever ran into the same problem and needed a quick fix...
Replace fuel pump without dropping gas tank Jymmm Expedition & Navigator 19 09-08-2016 12:53 AM
2012 5.0 Plug Change. David W Jones 2009 - 2014 F150 6 02-02-2016 10:55 AM
How to replace your fuel filter on a 2004 and newer F150. superrangerman2002 2004 - 2008 F150 96 05-14-2013 01:14 PM
Fuel pump replacement, 1997 asavage Aerostar 7 10-12-2012 03:18 AM
Fuel Filter Replacement dharrack 1987 - 1996 F150 & Larger F-Series Trucks 8 05-05-2010 01:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
