P2096
My truck gave a P2096 this past weekend. Cleared it and drove around for a while. Today it threw the same code. No other codes present, just P2096.
I did look under the truck and it seems pretty easy to get to the two sensors. Is it worth swapping them to see if the code changes to the other side?
Truck idles and accelerates just fine. Fuel mileage seems to be down a bit, but the air filter is very dirty and I will be replacing that this week.
Other suggestions? I have also seen you can check the sensor by hearing it and mearusre the voltage. Seems easy enough to do, but do you create other problems from that?
Thank you
Thank you
