Cubic Inches
That gives you a 306 and probably no measurable difference in power. You gain 4 CI, but you lose just a tick of compression.
Is this just a clean up bore during a rebuild?
http://www.wallaceracing.com/cid.php
Checked a couple of static CR calculators. You are correct, you get a bit of a boost in CR with a bigger bore, all else being the same.
Dynamic compression....not sure, but given the marginal volumetric efficiency, I don't see how you gain cylinder pressure while running. I suppose there is a standard, known calculation for that as well, but I don't feel like looking it up and proving myself wrong again.
Op hasn't been back yet.....
jonezzzman
11-19-2013 12:20 PM
econoshorty
09-06-2010 11:24 PM
rusty70f100
28
11-08-2005 10:25 PM
Annihilator
26
03-03-2005 05:45 AM
debestuss
16
09-22-2004 07:52 PM
