400 CRACKED BLOCKS
Old 08-26-2014, 12:01 PM
TMI's Avatar
TMI
TMI is offline
400 CRACKED BLOCKS
Technical update. On-line information says the Michigan casting after March 2,1977 is OK.
This is a Michigan casting, March 25,1977 and it is cracked, NOT OK.
Old 08-26-2014, 11:17 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
Thanks Tim!
I noticed that the Midnight Modified block does not have the large ridge next to the distributor, is that indicative of a certain casting facility? My current build also lacks that ridge, but I have seen many 351M/400 blocks that have it.
Also is there a date when the Michigan Casting Center (MCC) blocks began displaying a cracking issue? Ending later than we thought it looks. Can they be effectively sonic checked to determine suitability for rebuilding?
Thanks again!
Old 08-27-2014, 04:37 PM
77_F150_4x4's Avatar
77_F150_4x4
77_F150_4x4 is offline
Sad to see the crack issue widen on date cast.
Tim, I know I have never seen any info on other casting locations. I know my engine was, well the truck was delivered to the dealership in November of 76. Began life as a 351M, and it carries the CF casting(Cleveland Foundry I would believe). Never came back with cracking issues from the machine shop.
Curtis
Old 09-04-2014, 01:22 PM
blackjack33's Avatar
blackjack33
blackjack33 is offline
Thanks for the update Tim.
Old 09-05-2014, 11:16 AM
beartracks's Avatar
beartracks
beartracks is offline
As for the ridge on the block. As I understand it all factory 351m and 400 have a high ridge, 351c ha a low ridge. I has to do with the deck height.
Old 09-11-2014, 09:11 AM
mike240zt's Avatar
mike240zt
mike240zt is offline
when I built my 400 the first block cracked after being baked. if I remember right it was about a month after the so-called good date.
Old 03-23-2016, 04:03 PM
MUDBUCKET's Avatar
MUDBUCKET
MUDBUCKET is offline
This doesn't make me feel very good about the block I just got done breaking down, 7C16...I know this thread is a little old, but has this been found to be as big an issue as pre 7C01 blocks?
Old 03-28-2016, 04:15 PM
hollenjoe's Avatar
hollenjoe
hollenjoe is offline
Well i have a 400 73 Michigan block that has withstand 2 rebuilds and one with aluminum heads, your pistons and a mild roller cam, and still rolling....
In my opinion the weak blocks could be all blocks that don't have the reinforced lifter valley....
Old 03-28-2016, 04:35 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
That's a lot of blocks
Buldog
25
02-26-2019 05:04 PM
kegger66
07-07-2016 07:59 PM
jerm111
12-11-2009 11:05 PM
ibleedblue1385
06-16-2008 07:59 PM
jb85302
11-01-2000 04:30 PM
Quick Reply: 400 CRACKED BLOCKS
