Getting the underboost shake again
#31
#32
#33
I'm running the archoil 2300 now with Delvac 5w40 in an attempt to clean the spool valves. I'll know how successful this is this winter, but it appears I'm getting 1mpg better mileage in the 1000 miles since the change.
#34
We'll today they said injectors where good. Truck still had a very slight shutter and is starting to have an extended crank as the temps drop. I think I'm Gona send my ficm to Ed to get checked. The other question is with no codes do you think I should replace the ebp sensor and pig tail?
#35
Different path here.
I was getting a bad shake, it would rattle everything.
Turned out to be the Fuel Injection Wire Harness, turns out they rub on everything under the hood even though they were upgraded in late 2004, they are still an issue, mine (2005) had about 3 spots that were worn through and 1 broken plug, most likely from the head gasket job at the local dealership, no codes at all, my new shop found it by wiggling all the injector plugs while it was idling, the harness is under $200.00, available everywhere, again pointing to a large number of failures.
#37
https://www.ford-trucks.com/forums/1...see-video.html
Maybe a sticking intake or exhaust valve?? Let us know what you find.
#38
Unusual that the next reply said their #8 cylinder was dead, but that was the cylinder that was bad on mine and it was from a bad F.I. harness, that was the most worn spot, when the tech moved the harness the idle noise went away.
Can't say that's your problem, just sounds kind of like mine.
Oh, one more thing, 3 weeks after I had the F.I. harness replaced, the logic side of the FICM died, power side good.
I also have new batteries and alternator, 10 months old, no charging issues, good power.
Good Luck
#39
#40
This video is facing up hill
http://s1336.photobucket.com/user/ia...ohijp.mp4.html
This is facing down hill
http://s1336.photobucket.com/user/ia...93x68.mp4.html
Why is the icp psi taking so long to build down hill?
#41
