Just saying.....
Just saying.....
Purchased an 05 Diesel X couple months back.
Almost done with the install of the X/Bmod suspension upgrade from Cary.
This is the second time I've done the install (previously done on my 03 X V10)
So for conversations sake ... the second install was a ball buster just like the first!
No real problems doing it, not stalled on anyone item, just these trucks are BIG and everything including the necessary tools to work on them are HEAVY!
Not complaining... Just saying....
While I'm in no hurry to do it yet, I'm in the process of sourcing parts for the V/B code swap on my '05.
The rear springs are sitting on the overload/bump stop and I can comfortably squeeze two fingers between the bump stop and spring on the front. So it's on my "to do" list
Haven't done this on anyone's truck yet, but I've read that taking the front bumper off makes life much easier when it comes to the front springs.
I still have the original sticker on the drive shaft something like "Spicer March 2001". My floor pan is gray with overspray of Toreador Red.
Your SoCal truck should be clean also.
Lol, purchased the Ex in Northern Illinois where it spent its' first 6 years.
Finally washed all the salt off in 2006 when moved to So Cal.
Now it sees only sage brush and desert dust. Maybe a salt flat here or there.
Yes Was totally kidding I'm used to pulling engines that produce power that makes the 6.0 look like a 5.4 with 7 of the spark plugs missing but then again we need an overhead crane to pull them I have a decent tool set, but nothing like I had before and worst of all no air compressor since we moved to VA. so I have to start over again building back up
Took me that long to get it up on the Jack Stands and get the tires off the rear!
goldsmje
03-09-2008 09:59 PM
